2wd to 4wd
24 Dec 2022 01:15 #246513 by joe
2wd to 4wd was created by joe
I live in Japan and have a 660cc, 2007 XG, auto Jimny and I have a question about going from 2wd to 4wd. It's now the snowy season here and often the snow on the main roads is completely compacted, but very slippery. Because the terrain is mostly flat, and because of the low speed I have to drive at, the tyres are not scrambling for traction, but occasionally on small inclines they do, and occasionally it can get a bit hairy.
Also, when I get to said slight incline in 2wd, I need to switch to 4wd to make it up the hill. Do I need to stop the car in order to do this? Or can I press the 4wd button on the move?
I'm just worried that when I set off to work on flat terrain in 4wd (knowing that I have a small hill en-route) that I'm doing some damage.
Thanks,
Joe
24 Dec 2022 06:47 - 24 Dec 2022 06:51 #246514 by yakuza
Replied by yakuza on topic 2wd to 4wd
On a smooth surface going straight with little load and no wheelspin, you can Just push the button.
At high speed there is less use for the 4x4, but no harm in it being on as long the surface is snow. Do not use it on black asfalt as that will cause strain on the drivetrain.
Last edit: 24 Dec 2022 06:51 by yakuza.
The following user(s) said Thank You: joe
24 Dec 2022 22:59 #246537 by RainerK
Replied by RainerK on topic 2wd to 4wd
For my 2015 Jimny the manual states that 4WD can be turned on while driving up to 100kmh. For 4 WDL the car has to stop and be in N.
Merry Christmas!
25 Dec 2022 12:32 #246540 by joe
Replied by joe on topic 2wd to 4wd
yakuza and RainerK, thanks for your replies.
I'm just wondering, how does the drivetrain differentiate between black asphalt and compacted snow that doesn't cause tyre slippage? Most of my journey to work is on the latter with only 10% dodgy roads inclines.
(To clarify: 90% is dodgy - very compacted snow with some parts extremely icy and slippery in 2wd, but if I drive slowly, I can make it without tyre slippage, however, any lack of concentration, I'm in the ditch. The other 10% is hilly and needs the 4wd option.)
Best,
joe
25 Dec 2022 17:22 #246541 by Busta
Replied by Busta on topic 2wd to 4wd
It doesn't. That's why you need to be careful to only use 4wd when necessary.
25 Dec 2022 17:30 #246542 by Roger Fairclough
Replied by Roger Fairclough on topic 2wd to 4wd
2 wd is power to the rear wheels only. This mode is used on a sealed surface, ie concrete tar or asphalt.4 wd is used on slippery surfaces and that most definitely includes any form of ice and any form of snow whether it is compressed or otherwise. You do not wait for the Jimny to start slipping, you engage 4 wd so that power is distributed to all 4 wheels. This will help you to maintain traction. You will need to moderate the power you are using. Do not expect to be able to travel at your normal dry road speeds even when in 4 wd.
If you can, find a smooth level piece of ground covered in snow and experiment, firstly in 2 wd and then in 4 wd. Note how 4 wd gives you greater control but also note that 4 wd does not improve your braking.
Merry Christmas.
Roger
Time to create page: 0.173 seconds
