Need some assistance.
- Thank you received: 1950
10 Nov 2022 14:00 #245871
Replied by Lambert on topic Need some assistance.
It's schedule 10 304 stainless tube od is 26.7mm. the feet are welded so shrink tubing is probably out as the feet are 100mm minimum. Handle bar tape sounds good as does the solid rubber.
- Thank you received: 644
10 Nov 2022 14:14 #245872
Replied by DrRobin on topic Need some assistance.
Sorry, didn't realise the feet were welded on. Handle bar tape would be a good option.
The only other suggestion is what we swapped using the heat shrink at work to self amalgamating tape, (rubberised tape) which sticks to itself, just wrap it with a slight overlap. If you stretch it slightly it reduces thickness and gives a nicer finish, but might not be a neat as the handle bar tape.
Screwfix and Toolstation both sell it.
- redoregan
10 Nov 2022 15:13 #245873
by redoregan
Replied by redoregan on topic Need some assistance.
If it were me I'd probably use hurling tape that we put on wooden hurls for grip.
10 Nov 2022 15:29 #245875
by Busta
Replied by Busta on topic Need some assistance.
Plasti dip? It's a paintable rubbery plastic.
10 Nov 2022 17:34 #245880
by Scimike
Replied by Scimike on topic Need some assistance.
I use the grey pipe lagging, as you have already suggested.
QUick to fit, grips very well and provide protect for both the bar and load. You can even leave it fitted if you want, but I remove when not in use.
10 Nov 2022 18:38 #245881
How do you attach it, zip ties or just it's own recognizance?
