Front Seat Removal
- Thank you received: 493
21 Oct 2022 13:21 #245514
Front Seat Removal was created by DrRobin
I am planning on changing my seats and runners this weekend and just wondering about the best way to take the old seats out.
Do you unbolt the seats from the runners and then take the runners out, or is better just to remove the runners and lift the whole lot out together?
Ta
Robin
Ta
Robin
- Thank you received: 1814
21 Oct 2022 15:33 #245517
Replied by Lambert on topic Front Seat Removal
Either the front 2 floor bolts then the back or vice versa. Then lift the whole assembly out in one piece.
- Thank you received: 663
21 Oct 2022 16:01 #245518
Replied by jackonlyjack on topic Front Seat Removal
+1 with Lambert
If you pull the leaver and tilt seat forwards it's even easier to lift them out
weigh around 20kg
weigh around 20kg
21 Oct 2022 17:04 #245519
Replied by DrRobin on topic Front Seat Removal
Thanks guys, it looks quite straight forward.
I will need to take the seat belt off the old seats, but that should be easy once they are out.
I am going to keep the stock seats for a while, it might be easy to swap back if the misses doesn't like the new seats.
21 Oct 2022 19:08 #245520
You will need a nut and bolt for seat belt stalks
The original nut is welded to the seat base and it is a strange thread size
22 Oct 2022 08:18 #245524
The seat sub frames include a nut a bolt for the seat belt.
I will be having a go at fitting them today.
Robin
Robin
Time to create page: 0.162 seconds
