location of the mass airflow sensor
12 Sep 2022 14:00 - 12 Sep 2022 14:54 #244935
by danielbz
location of the mass airflow sensor was created by danielbz
hello
i have a jimny 1.5 2017, does anyone knows where is the mass airflow sensor? i tried the tube before the inlet but it just have a plastic sensor look alike
regards
regards
Last edit: 12 Sep 2022 14:54 by danielbz.
- Thank you received: 648
12 Sep 2022 14:09 #244936
Replied by DrRobin on topic location of the mass airflow sensor
Hi,
It's in the tube leading away from the air filter (close to the air filter) on my 2011 1.3L. I would imagine it is in the same place on the 1.5, that is certainly the common place for it.
Is your Jimny the 1,500 diesel?
Robin
Robin
12 Sep 2022 14:32 - 12 Sep 2022 14:45 #244937
by danielbz
Replied by danielbz on topic location of the mass airflow sensor
hello
its gasoline, i already opened that tube but there was the air change temperature sensor, its a small plastic, that cannot be it
the one i found there was 11C12-170400 6010
Last edit: 12 Sep 2022 14:45 by danielbz.
12 Sep 2022 15:17 #244939
The part number says it is an air temperature sensor for a Toyota or some Suzukis, but doesn't mention Jimny.
I must admit, I am confused Jimny Gen4 with a 1.5 engine didn't start shipping until 2018 (at least in the UK) and gasoline before that was only 1.3, do you know which engine is fitted in yours? E.g. M15x, K15x?
