255/70/15 yay or nei?
  • Barakyo029
03 Sep 2022 17:28 #244845 by Barakyo029
255/70/15 yay or nei? was created by Barakyo029
Would a 255/70/15 with a 2" lift kit fit in a jimny? First, i have a stock 2013 jimny and i plan to lift it to do some offroading, also a lifted jimny looks nice and will become more capable offroader. I have been reading around the forums and i havent seen a thread that will help me enlighten my question.
why i chose 255/70/15 29.1" tall
1.  i think its because its below 31" on which i am required to change some gearings
2. With 2" lift kit i "think" it would not require trimming or at least a minimum trimming along the wells and fenders and stuff or at least it will help provide a bit of clearance along the wells 3. With 255's it would look nice and snug on it without spending too much
please help me with these assumptions that i have in mind
03 Sep 2022 18:44 #244846 by fordem
Replied by fordem on topic 255/70/15 yay or nei?
I'm guessing here, but my guess is based on my experience with my JB74 Jimny, AND also other Suzukis, with larger, more powerful engines than the M13 that you most likely have in that 2013 Jimny.
My guess is you're really going to feel the impact of those larger, heavier tires, not only in the way the vehicle accelerates & in the fuel consumption, but also in the way it stops.
255/70s are going to be too wide for the stock 5.5" rims, you're probably going to need, I'm guessing (again) at least an 8" wide rim,
I'm going to refrain from guessing on how much trimming you're going to need to do, because we're discussing a vehicle that I'm not familiar with, and I have no idea what the offset on your new wheels will be, but I will say that when you're discussing tires as wide as you are, you need to carefully consider the arc that the outer edges of the front tires follow as you turn from lock-to-lock - it might require more than just "minimum trimming" - I went from a 235/60R16 on one of my Suzukis to a 235/70R16 and these slightly larger tires hit the frame on full lock.
03 Sep 2022 19:51 #244848 by Lambert
Replied by Lambert on topic 255/70/15 yay or nei?
255.70s on a Jimny will need significant trimming as they are monstrously wide. They will also noticeably reduce ground pressure which is only useful for very specific terrain conditions like sand and bottomless swamps. What they won't do is cope at all well with wet tarmac. I would look at something narrower with the same height, that will be easier to get inside the wheel arch at full compression. Wider isn't always better.
  • Barakyo029
03 Sep 2022 21:08 #244851 by Barakyo029
Replied by Barakyo029 on topic 255/70/15 yay or nei?
What tire would you suggest?
  • Barakyo029
03 Sep 2022 21:14 #244852 by Barakyo029
Also what lead to me at this assumption is that my friend is rocking a 31/10.5/15 rims, should i take that into consideration?
04 Sep 2022 04:59 #244854 by Lambert
Much bigger than a 235.75r15 will need some kind of regearing. You can go as big as you like but it starts getting increasingly difficult. There are some out there running 37s but they are a long way from a standard ish Jimny.
Time to create page: 0.319 seconds
