Re:Brake caliper sliding pin removal
- gilburton
28 Jul 2022 14:11 #244262
by gilburton
Brake caliper sliding pin removal was created by gilburton
Can't find much info about getting stuck pins out and what info there is seems to be a bit old.
I just want to know if anyone has any good techniques to remove them?
I know you can get replacement pins but I'm still reluctant to bash them with a big hammer. I have tried that slightly but it just seems to turn the edges over.
Please note I don't have any heat equipment apart from a heat gun.
I just wondered if there were any good puller ideas and does this involve takeing the calipers off and put in a vice??
I don't need info on cleaning or replacing them just how the hell can you get them out
28 Jul 2022 15:44 #244270
Replied by mlines on topic Re:Brake caliper sliding pin removal
The pin is a fairly loose believe it or not. Usually it is the rubbers that have expanded and jam the slider
Sent from my moto g42 using Tapatalk
- gilburton
28 Jul 2022 17:17 - 28 Jul 2022 17:19 #244272
by gilburton
Replied by gilburton on topic Re:Brake caliper sliding pin removal
I tried pulling the rubbers off but they seem stuck inside the hole both sides are you supposed to slide the pin a bit to one side get one off and then slide it the other way?? If I could get them off at least I might be able to get wd40 or similar on each end to try and free it off.
I started to replace the pads on what would be less than an hours job and found that the tyre fitter had obviously had his industrial size rattle gun turned up full and had to use a 6ft pipe to get the wheel nuts off so that didn;t start well then the caliper bolts were no problem but one pin is stuck out a smidgeon(technical term) so the caliper wouldn't clear and swing back into place with the new pads. The swearing started about then lol
Last edit: 28 Jul 2022 17:19 by gilburton.
28 Jul 2022 17:54 - 28 Jul 2022 17:57 #244273
You are not alone....
www.bigjimny.com/index.php/bigjimny-blog...sive-mistake-v15-247
See the oil effect here....
www.bigjimny.com/index.php/bigjimny-blog...sive-mistake-v15-248
And when you have cut them out, the kit is here
www.bigjimny.com/store/caliper-fitting-kit-aisin.html
Last edit: 28 Jul 2022 17:57 by mlines.
- Thank you received: 1992
28 Jul 2022 19:01 #244276
Replied by Lambert on topic Re:Brake caliper sliding pin removal
I've had difficulty like this in the past and it was a pair of knipex cobra pliers that saved the day by working the slides rotationally over too long a period for the good of my mental health. It chews the ends but I had replacements. It's also worth having a bit of sandpaper on a stick to make an internal flap sander for the drill to clean up the caliper bores.
31 Jul 2022 18:14 #244337
by Velocette
Replied by Velocette on topic Re:Brake caliper sliding pin removal
Two methods. First is find a bolt about 5" long, grind or file the head down until it will fit over the pin but through the hole it fits in. A piece of pipe or a socket just larger that the pin, a suitable washer and nut and you have a custom extractor !! Any extra heat you can apply will help.
Second way is to thread a junior hacksaw blade through the pin, refit to the hacksaw frame and proceed carefully.
Guess which way worked for me.
Time to create page: 0.195 seconds
