Re coils
4 years 5 months ago #243751 by Rackster
Coils was created by Rackster
Hi guys the diagnostic thing says intermittent misfire I have changed the plugs still the same looking for some decent after market coils as the originals are very pricey what do you think  cheers Rackster
4 years 5 months ago #243755 by DrRobin
Replied by DrRobin on topic Coils
My other car developed a misfire last year and I went down the route of checking everything, eventually changed spark plugs, coil packs, O2 sensors, MAF sensor, cleaned the throttle body, flushed the fuel, pretty much everything.
It turned out to be a low battery. When the battery was fairly flat the car would start and run OK, but get a misfire after deceleration to low revs and then feeding in the power.
If I kept the battery charged, it never misfired.
Have you tried cleaning the coil packs with switch cleaner and inspecting for cracks? If the misfire is random, it probably isn't the coil packs and likely to be something else, CAM position sensor, poor earth fuel, etc.
Robin
4 years 5 months ago #243756 by Rackster
Replied by Rackster on topic Coils
Thanks for that Robin when you say low battery how low?mine was 12.5 volts the other morning before start up I will put it on charge tonight and see what happens
Cheers Rackster
4 years 5 months ago #243762 by DrRobin
My other car is not a Jimny, so comparisons might be difficult, but battery voltage was around 12v before start up. Indicated voltage when the misfire occurred was 14v, but at low revs, 1,500 rpm in top gear. Although voltage was good at low revs the alternator probably couldn’t supply the pulse currents for the injectors/ignition these would need to be supplied by the battery and if it was weak it probably struggled leading to a weak spark or incorrect firing of an injector.
When does your misfire occur, low revs, high, any pattern to it?
Robin
4 years 5 months ago #243764 by Rackster
Hi Robin it occurs at low revs I'm a keeper and have to stop and open gates you can hear the exhaust popping intermittently then drive off ok
4 years 5 months ago - 4 years 5 months ago #243766 by Scimike
Replied by Scimike on topic Coils
Since the advent of smart alternators and such clever stuff a problem with the battery can manifest in many ways,missfire included.
However on the early generation Jimny (not G4) so long as your alternator is working a battery problem is unlikely to cause a missfire unless it's serious enough to pull the alternator voltage down.
12.5 volts at rest is ok, but more importantly it should be 14v with the engine running. If it stays around 12.5 - 13 volts something wrong with the battery or charging circuit.
If you are uncertain Halfords can check your battery and charging circuit for free. Go to a store without an auto center as the ones with will try to book it in as a garage service, at the stores without they can't so it's free.
Last edit: 4 years 5 months ago by Scimike.
