Anyone here with experience on chunky mud tyres? (esp Bridgestone M/T 674)
  • gymny2021
11 Jun 2022 09:39 #243670 by gymny2021
Hi guys! long time reader, first time poster.
I have a 2021 Jimny that I've been driving off road quite a bit on the stock tyres, it has reached the point where chunks of rubber are missing and one of the tyres was punctured so looking for new tyres.
I have my eyes/heart set on the Bridgestone DUELER M/T 674 235/75R15 but I'm a bit nervous due to clearance and on road noise/performance - and also if it's suitable to install on a Jimny with stock suspension (rather not raise the height as most of my offroading is on extremely steep terrain and being low to the ground has probably helped save me a few times).
11 Jun 2022 13:50 #243672 by fordem
If you've been able to get where you want/need to go on stock tires, my suggestion would be 215/75R15 in an all terrain pattern - mud terrains on road are going to wear quickly and possibly be noisy.
Anything wider than a 215 will require replacement of the rims, and although the 215/75 is only a hair taller than the stock 195/80, it is enough that you can feel the impact in on road acceleration, going wider/taller is going to have a greater impact, and you may find it necessary to consider re-gearing to make it up that "extremely steep terrain".
A tire wider than a 215, depending on the rim offset, will probably require a wider arch extension to be fitted in order to keep the wheels covered, along with mud flaps to keep the mud off the side of the vehicle.
I went with General Grabber AT/X in the 215/75R15, it's a fairly aggressive all terrain tread pattern, as mentioned earlier, the impact of the added height & weight were enough to be noticeable, I have the 5 speed manual, if you're running the automatic, it might be less noticeable - if you are running the automatic, consider fitting a transmission temperature gauge - it's easy to "cook" them.
13 Jun 2022 09:05 #243683 by saxj
I have 235/75R15 General Grabber X3 muddies on my Jimny. Noise is a factor, wear is not. I have had mine on for about 70000km and they still have plenty of tread left. I have them fitted to the stock rims and they are fine. Re-gearing for "extremely steep terrain" is not required. The Jimny handles any terrain in low range.  The 235's fit within the arches, so that isn't an issue, but you may experience some rubbing. I have a 2" lift on mine.
There are a few downsides however to M/T tyres especially in that size. 1. On road handling is compromised a LOT. Wet handling is very poor. 2. Noise - They are very noisy, but turning up the radio helps. 3. On road performance is a lot worse, you'll find yourself gearing down to 3rd on hills where the stock tyres you could use top gear. 4. Fuel consumption takes a huge knock.
Would I change back, no, they are just so much better off-road. I have learned to live with the down sides, and just dig a little deeper into the pocket for fuel.
13 Jun 2022 09:27 #243684 by yakuza
I agree with some of the above here.
Wet handling is poor after the tires get hard and a few years old.
The BFG do not wear out fast, other softer may wear faster and they may also have better wet handling.
235 without changing the gears, I would not do it again. i would stay with max 215.
Tire and rim width is not a problem up to 235 tires. They wear evenly with the correct tire pressure. Yes, i know some suppliers do not approve.
235 do not require arch extension in all markets and countries and depends on rim width and rim offset/backspacing. Should be fine with the original wheels.
clearance for 235 require either a lift or cutting. it is varies alot how much rubbing is acceptable. For some none, and for others alot. (and how much is that? :) )
13 Jun 2022 09:37 #243685 by saxj
He is talking about a Gen 4. No cutting required.
13 Jun 2022 10:12 #243688 by yakuza
Sorry, thought they need a lift or cutting to fit 235 with no rubbing. :)
