Vehicle has fuel but still shows reserve light on and fuel pump not powering up
  • Greakking972
24 Apr 2022 01:46 #243103 by Greakking972
Vehicle has fuel but still shows reserve light on and fuel pump not powering up.
Vehicle is cranking Up but not starting
24 Apr 2022 05:05 #243105 by Lambert
Welcome to the forum. First what age is the Jimny, second have you checked the fuses?
  • Dirtbird
24 Apr 2022 08:32 #243107 by Dirtbird
Check your fuel pump relay. They are two relays in rubber housings that are slotted onto two fins beside the main fuse box beside the battery under the bonnet. I think I swapped the two of them around just to see if the fuel pump engaged.
  • Greakking972
24 Apr 2022 10:32 #243116 by Greakking972
The Jimny is a 2009 year one of the jb43 models I replaced fuel pump with a new one only to find that the new pump isn’t being powered up but both the old and the new fuel pump works perfect when tested on a 12v battery
  • Dirtbird
24 Apr 2022 10:42 #243117 by Dirtbird
Greakking check the relay by swapping them with each other and 9 times out of 10 it's a €5 replacement relay.
  • Greakking972
24 Apr 2022 15:54 #243126 by Greakking972
I did swap the relays but the issue still continues. What else can possible cause this issue.
Time to create page: 0.576 seconds
