Off topic - infrequently use Motorbike and modern petrol
- Thank you received: 553
03 Apr 2022 20:20 - 03 Apr 2022 21:00 #242712
by Scimike
Off topic - infrequently use Motorbike and modern petrol was created by Scimike
Slightly off topic, but may apply to those that don't use their Jimny much.
I've messed up. I left one of my Motorbikes longer than I should have done, fully aware that petrol goes off. I put in stability additives and filled the tank. I expected the petrol to be "off" when I looked, but did not expect the corrosion and general carnage that had developed. I am in the process of fixing the damage (£££), but how do I prevent this in the future?
Not sure filling the tank is still sound advice as most of the damage was below the petrol line, figure that out! The additives did nothing and a subsequent search of YouTube is starting to confirming similar.
So going forward what do you do to stop E10 / E5 damage on vehicles (or chainsaws etc) used infrequently ?
At the moment I am moving towards a drained system with a tank part filled with Aspen 4 and oil, sort of a reuse storage liquid. Bit of a pain as I need to drain at the beginning of each season, but it is reusable at the end of the season.
The take away is that if you don't use your E10 filled Jimny for 12 months worry, it's awful petrol. Forget less mpg, it's filling you fuel system with water and rust (like it needs more rust )
Any suggestions welcomed, except use it more until I retire.
Last edit: 03 Apr 2022 21:00 by Scimike.
- Thank you received: 632
03 Apr 2022 21:32 - 03 Apr 2022 21:41 #242713
Replied by DrRobin on topic Off topic - infrequently use Motorbike and modern petrol
I was advised to remove the fuel pipes from the carbs on my classic motorcycle (1977 Triumph 750) apparently the fuel taps leak. I didn’t bother and after leaving it for 5 years, I just dropped the float bowls off the carbs and cleaned the residue out, it was fine.
If you leave a vehicle for a while, leave a little fuel in the tank, it stops it going rusty inside, then drain and refill with fresh fuel before starting and you will be fine.
Don’t worry about the oil either, that will be okay, I mean it is largely in a closed system and oil has been around for 1000s of years, it’s not going to go off after a few years sat in an engine.
Robin
Robin
Last edit: 03 Apr 2022 21:41 by DrRobin.
The following user(s) said Thank You: Scimike
- Thank you received: 1939
04 Apr 2022 03:24 #242715
Replied by Lambert on topic Off topic - infrequently use Motorbike and modern petrol
Being off grid I have a few small engines that I don't use every month and I just drain them. It can't go off if it's not there and that was before the advent of the waterlogged petrol we have to put up with nowadays.
04 Apr 2022 08:11 #242716
by Busta
Replied by Busta on topic Off topic - infrequently use Motorbike and modern petrol
I put E10 in everything. If I'm using one bike and another is sat with old fuel in it I syphon that over to the bike that is being used so I can burn it up before it goes off. Then the other bike will sit empty until I need to ride it.
Under use is no good for any vehicle. My most reliable things are the ones I use all the time, and that extends far beyond fuel issues. Same goes for never emptying a tank. I've bought bikes off people that are afraid to use reserve and the result is always a collection of crud in the bottom of the tank. Regularly running a a vehicle dry (or as close to it as practical) helps keep on top of any buildup in the tank.
04 Apr 2022 08:43 #242717
by LesNewell
Replied by LesNewell on topic Off topic - infrequently use Motorbike and modern petrol
The ethanol in E5/E10 loves to absorb water and cause rust. If you are leaving anything with an engine more than a month or two the best thing to do is drain the tank then run the engine until it stops. This completely drains the fuel system. It's particularly important to do this with two strokes. To do a really good job, take the plug(s) out, squirt in some oil and spin it over a few times before replacing the plugs. This helps prevent rust on the bores.
If you have a metal tank and you are really paranoid, leave the fuel cap off for a week or so. This allows the tank to completely dry out, including any water that may have collected in the bottom.
04 Apr 2022 18:46 - 04 Apr 2022 18:46 #242724
by Scimike
Replied by Scimike on topic Off topic - infrequently use Motorbike and modern petrol
Thanks all.
It looks like the big mistake I made was filling the tank full. It was (and still is) in some instances the recommended action to take for storage.
I think it longer applies to E fuels.
I have saved the very rusty tank. I used Evaporust (never used before) and its amazing witchcraft for submerged rust removal. I've now sealed the tank with a POR-15 tank kit. I have used POR before and just like the other products its good. Recommended products.
Next the carbs, I hope I drained them or they are going to be stuffed.
Last edit: 04 Apr 2022 18:46 by Scimike.
Time to create page: 0.219 seconds
