Roofrack or towbar rack?
22 Mar 2022 18:57 #242453
by treps
Roofrack or towbar rack? was created by treps
For the few occasions when I have to carry people and luggage I am looking at options for my 2020 Jimny.
Searches bring up £1k roofrack options. They look good but for my infrequent use are an overkill and I am concerned about the high weight.
Towbar racks such as Thule, alone or with a box look practical but I have no experience of them.
Luggage carried would be one or two suitcases from an airport and that is it. Any advice appreciated. Thanks in advance.
- Thank you received: 1999
22 Mar 2022 19:16 #242454
Replied by Lambert on topic Roofrack or towbar rack?
I have roof bars and I find them immensely useful but they do nothing good to my MPG. I have considered a roof box but they are even worse for fuel use. The idea of a basket out the back out of the airflow sounds good. Also I believe the vertical load on the towbar is 50kg compared with 30kg on the roof.
The following user(s) said Thank You: treps
22 Mar 2022 21:49 - 22 Mar 2022 21:56 #242457
Replied by Soeley on topic Roofrack or towbar rack?
I have the Thule roof bars, they are the same as the Suzuki offering but about a third of the price if you shop around. I also got an aluminium roof basket which is very light weight, that I can use with the roof bars.A good And versatile option in my opinion.
Last edit: 22 Mar 2022 21:56 by Soeley.
- Roger Fairclough
- Thank you received: 225
22 Mar 2022 22:18 #242458
by Roger Fairclough
Replied by Roger Fairclough on topic Roofrack or towbar rack?
What about using a taxi?
Roger
Roger
23 Mar 2022 09:50 - 23 Mar 2022 09:51 #242461
by Scimike
Replied by Scimike on topic Roofrack or towbar rack?
It's fair to say all are solutions to your requirement, even the Taxi
A roof system can be fitted and left in place, in its simplest form (Thule Aero Bars or similar) its not adding much weight or drag.
However, in its simplest form, its awkward to attach cases and possible to damage the vehicle roof during attempts to balance the cases on two bars. For this reason a roof rack cage is better, you can just throw the cases on top and tie down. The down side is the rack cage is heavy and adds drag / wind noise and is not something you can quickly fit to the vehicle.
A towbar system such as the Thule EasyBase is easy to fit if you have a towbar, but the combined cost of the two items is expensive. The maximum noise weight limit on the tow bar will be dictated by the towbar system manufacturer/ Thule, but its typically in the region of 50 - 75KG for towing. The down side of these systems is you will forget its fitted and eventually reverse into something !
If you can remember its fitted I suspect this could be the best solution for the airport run.
A taxi ? - why not. Its a good idea if its infrequent use and they tend to be reliable. The down side is you need to make small talk to the driver and the journey will range from sedate to Death Race 2000.
I went for an adventure roof cargo system as I needed a space to throw wet camping equipment quickly onto the vehicle. Its perfect for my needs, but has added slight wind noise. I've not seen a noticeable increase in MPG but suspect one must exist simply as its added weight and drag.
Last edit: 23 Mar 2022 09:51 by Scimike.
- Roger Fairclough
23 Mar 2022 12:11 #242463
by Roger Fairclough
Either treps has a tow bar or is contemplating having one fitted in which case another idea is to use a trailer. Once you have one the list of things you can do with it broaden so it's not just on the odd occasions you need to pick people up from the airport.
Taxi drivers, from personnel experience, are certainly better than yesterdays ex. racing drivers and as a point, Viv and I came back from Napton to Bromsgrove last Monday in a 7 series BMW auto which was wafting along the motorway at 75 mph (1500 rpm) at a responsible distance from the vehicles in front. All in all an easy drive. The driver told us that Redditch to Birmingham International Airport was £40 each way ( that's about 20 miles ).
Roger
Roger
Time to create page: 0.197 seconds
