Newbie, any advice welcome
- Man of Kent
Topic Author
16 Mar 2022 19:59 #242354
by Man of Kent
Newbie, any advice welcome was created by Man of Kent
Hi everyone, I am looking to buy a second-hand petrol Jimny in Germany and exporting it to my home in Belgium, I intend to use it as just a run-about as I am retiring at the end of this year.
Any advice on what to check for mechanically and bodywork etc.
Model year will be between 2006/10 as that would be my price range, I would prefer a petrol but there are a few diesels on the market which I believe use a Renault 1.5 non-turbo lump.
Is the auto-box reliable?
Any advice gratefully received.
- Thank you received: 620
16 Mar 2022 21:28 #242355
Replied by DrRobin on topic Newbie, any advice welcome
Rust seems to be the main problem. There are various rust spots, just behind the headlamps, wheel arches and boot floor seem to be the main places but also near the body mounts is another favourite place.
Then there is the so called death wobble, at around 50mph/80km/h, this is often kingpin bearings or bushes, usually easy to fix, see the wiki.
My understanding is that the engine/gearbox is as reliable as any other model and there are plenty on here with automatics and don’t report any specific problems.
Check the four wheel drive including low range works correctly, usually it’s a switch or a vacuum hub/line which is at fault, but best to find out before rather than after.
The crankshaft drive belt pulley seems to be a weak component, again easy enough to change.
Summary, rust seems to be the main problem, a little surface rust on the chassis is normal, but it’s the body to look for. Again fixable, but try to find one which doesn’t need welding after buying.
Hope that helps.
Robin
Hope that helps.
Robin
- Man of Kent
Topic Author
17 Mar 2022 09:06 #242359
by Man of Kent
Replied by Man of Kent on topic Newbie, any advice welcome
Duly noted, it’s a pity I can’t buy one in the UK as they are much cheaper, but it’s rare to find a LHD one in the UK anyway, apart from that importing one now since Brexit will be a nightmare!
In Belgium and Holland they are expensive 2nd hand so that’s why I am looking in Germany, hope to go and view a few in the coming weeks.
17 Mar 2022 13:18 #242363
by Scimike
Replied by Scimike on topic Newbie, any advice welcome
Robin has everything covered, so just to say Hi and welcome, hope you find a nice one with no ROT (rust is the big number 1 issue)..
Try to get a test drive in an Auto / Manual / Petrol / Diesel before you decide which is for you, they will all have a different character set, everyone has their favourite.
They are not "car like" in performance or road manners. So unless you have experienced a solid axle 4x4 in the past be prepared to be ecstatic or horrified, they are a bit like Marmite!
Have fun
Have fun
25 Mar 2022 06:58 #242491
by JAGtheman
Julian
2008 Gen 3 Manual
Being completely revitalised
Replied by JAGtheman on topic Newbie, any advice welcome
I live south of München and work in the UK. Last year I bought a 2008 model in the UK and it has been a fantastic adventure. However looking at similar vehicles in Bavaria it is clear that they are real workhorses there. Common for the Hausmeister to fit a small snowplough and use it for winter service. The closer you get to the Alps the more Jimnys you will find, but again, these are used and used hard. The lower prices are deceptive, as Germans love their cars almost at a fanatical level, and they are very price savvy, so a bargain will be offered because of some underlying reason. Maybe you will find one, they do exist, but you need to be extra careful and certainly consider not only the vehicle itsself but how it has been used. Take serious note of the rust issue pointed out above, although vehicles in the EU did have a higher level of rust protection applied than in the UK. Body mounts top of list (dont just look, poke it with a screwdriver), behind the headlights, seat belt anchor points, rear boot where the jack is stored, brake drums (if they are rusted like crazy this is a good sign the rest of the underside is similar imo).
At 66 yo, and having owned many 4x4 vehicles of all shapes and sizes (I am an ex South African Land Surveyor), I can honestly say this is the best most fun 4x4 I have ever owned! Good luck in your search, the reward is well worth the effort!
Julian
2008 Gen 3 Manual
Time to create page: 0.170 seconds
