Fuel Filter location on 2020 Jimny Gen 4
  • martindinger
17 Feb 2022 22:43 #241897 by martindinger
Fuel Filter location on 2020 Jimny Gen 4 was created by martindinger
Hi,
Can someone tell me where the petrol fuel filter is located on the 2020 gen 4 model? I have conflicting information. Suzuki AU says it's intank Pt no SZ-15100-78R01 with a description of "Pump Assembly" priced at wopping AU$1328.90. Others say it's in the engine bay or next to the tank? I've looked everywhere and can't seem to locate the stardard "stand alone" inline filter. Reason I ask is that I've just had a  "longranger" 90lt tank fitted and the supplers fittting instruction say "Replace filter after 1000Km" . When I asked them where it is, they said it should be in the engine bay, but to check on Youtube? Great help that was !! I just don't want to drop the tank if it is inline somewhere.
Anyway if someone has a photo or and can point me in the right direction would be great.
Regards
18 Feb 2022 04:19 #241898 by Lambert
As far as I am aware it's in the tank, certainly Suzuki didn't have a separate one on the gen3.
The following user(s) said Thank You: martindinger
18 Feb 2022 05:20 #241900 by Old Neil
Like Lambert said, only place it would be in tank with fuel pump in it, bit of a mission getting that big boy tank out, can't imagine why so expensive, was it a quote to do the job
18 Feb 2022 08:44 #241901 by saxj
It's the same as the gen 3. It is in the tank, and doesn't need replacing.
18 Feb 2022 09:11 #241902 by Roger Fairclough
The only reason to change a filter is if it is contaminated so maybe the tank makers don't do a proper job of cleaning the tank out before selling it.
Maybe a word, or two, with them would be a good idea and yes, the filter is in the tank.
Roger
18 Feb 2022 10:39 #241903 by saxj
Roger
If that is the case,  you would need to drop the tank, remove the pump assembly and wash the filter.
Time to create page: 0.345 seconds
