Lift Kit Advice
16 Jan 2022 23:53 #241243
Replied by yakuza on topic Lift Kit Advice
I got the trailmaster comfort 2". Have not tried any other. Came with extended brake hoses.
I tried without the Castor correction, but I Think the car was awful to drive, did not center the wheels by itself after taking a turn at all.
Much better with the offset bushings.
Ride is good, but of course it is not a race car. Speed bumps are tackled at speed. No need to slow down as much But not exactly comfy passing them.
The following user(s) said Thank You: louchy
- Dirtbird
17 Jan 2022 10:54 - 17 Jan 2022 19:35 #241255
by Dirtbird
Replied by Dirtbird on topic Lift Kit Advice
I found the same yakuza on my precompiled shock and spring lift, the corrected castors should be recommended as part of the 2-inch lift if anyone considers it.
Last edit: 17 Jan 2022 19:35 by Dirtbird.
17 Jan 2022 11:44 #241257
Replied by mlines on topic Lift Kit Advice
That is strange as this is the one I supply and fit and I have never found castor correction necessary as it is a "low" lift (measured at 48mm on our cars)I got the trailmaster comfort 2". Have not tried any other. Came with extended brake hoses.
ng them.
17 Jan 2022 12:06 #241259
by louchy
2003 '53 Jimny JLX Mode
2" Suspension Lift
Modular Steel Wheels + Manual Hubs
BFG MT's
ARB Delete
Breathers (Diffs, Transfer Box, Gearbox)
Raptor 4x4 Snorkel
Jimnybits Armour (Diffs, Transfer Box, Fuel Tank, Shock Mounts, Rad Arms)
Front & Rear Recovery Points
Front & Rear Lightbars
Replied by louchy on topic Lift Kit Advice
ng them.
When are you expecting stock Martin?
2" Suspension Lift
BFG MT's
ARB Delete
Raptor 4x4 Snorkel
Time to create page: 0.192 seconds
