Gen4 MPG calculation
31 Dec 2021 02:42 - 31 Dec 2021 02:49 #240860
by Scimike
Replied by Scimike on topic Gen4 MPG calculation
It's too early to confirm one way or the other for me if E10 is worth avoiding, I just don't see any MPG variations that are unexpected for my use at the moment.
I am not guessing. For every tank fill I record the miles covered and the type of use, so I have a good idea of what range of mpg to expect for a certain type of use. It's the old fashioned way of doing what the trip computer now does, albeit with a lower sample rate.
I need to look at 12 months use before I can decide. Over my years of recording this data I consistently average near enough 35mpg over a 12 month period on E5, this appears to represent my typical use profile.
Just need to use E10 it a bit longer to get to the same comparison point.
Last edit: 31 Dec 2021 02:49 by Scimike.
- Thank you received: 659
31 Dec 2021 09:27 #240864
Replied by DrRobin on topic Gen4 MPG calculation
E10 is 4% less efficient, the air fuel ratio goes from 14.7:1 for standard fuel to 14.08:1 for E10, therefore on 33mpg you would expect to see about 1mpg less using E10.
E5 costs about 12% more than E5 so is unlikely to be worth it for fuel economy on its own. Perhaps the additives in E5 and if it is cleaner fuel can justify the extra cost?
The following user(s) said Thank You: Scimike
31 Dec 2021 12:08 #240866
by Scimike
Thanks. I had not seen any figures, just the bad press that's floating around. Explains why I can't see any difference, it's too small to see within my normal running variation. It should show later for me with more use and miles logged, but hopefully it's only going to be about 1mpg less if the math holds true.It's saving the planet? Don't get me started on that one, but is nice they spin things to give people hope
31 Dec 2021 12:08 #240867
by Dan
The lowest commonly available E5 is BP at 97ron.
www.bp.com/en_gb/united-kingdom/home/pro...tive-technology.html
Replied by Dan on topic Gen4 MPG calculation
Here in the UK E5 is 95 RON, perhaps in other countries where E5 is a lower octane rating it’s worth it, but not here.
31 Dec 2021 13:45 #240869
Thanks Dan, I meant to say E10 is 95 RON.
31 Dec 2021 15:06 #240872
by Dan
This time last year I didn't know anything about super unleaded, but as E10 will kill my chainsaws I had to learn quickly!
