Diesel engine upgrade
14 Dec 2021 21:04 #240651 by Martinm
Hi
I have a 2006 Jimny Auto. I am wondering what would be the best Diesel to put in it and would anyone have a ball park figure.
Since purchase I have carried out a few upgrades ie, side steps, bullbars, 50mm wheel spacers, suspension up lift and a snorkel.
Would be grateful for any thoughts love my Jimny so much fun almost forgot the steering damper no wobble at 40 mph.
Regards to all and happy Xmas. Be safe,
ps and new breaks and discs all round
15 Dec 2021 00:08 #240654 by Busta
Replied by Busta on topic Diesel engine upgrade
Diesel engine swaps are talked about regularly and finished rarely. I don't know anyone who has done one and then continued using the vehicle day to day. Most are either sold as unfinished projects, sold shortly after completion or used infrequently for off-roading.
Talking about the older mechanical pump engines is most popular, such as the Isuzu 1.7td found in 1990s Vauxhalls or the Peugeot 1.9XUD. Alternatively the VW 1.9PD is an attractive proposition. Some even like the idea of very low powered diesel engines like the Isuzu 1.3 and Peugeot 1.5tud. One bloke actually fitted a 30hp Kubota engine!
Once you've chosen the engine you need to consider what gearbox you are going to use. It needs to be longitudinal (rwd) arrangement and not too big. The Peugeot XUD engine can be mated to the gearbox from an LDV Pilot. A chap on here was making kits to fit the Isuzu engines to the Jimny gearbox a few years ago. I don't know if he's still about though.
That's just the start of it really. There's lots more to consider such as engine mounts, sump, propshafts, front suspension, gear ratios, intercooler placement, cooling, power steering, getting the dash to talk to it all, upgrading the driveline to handle the extra torque etc. etc.
Ball park figure to pay someone else to do it, I'd say £5k minimum for something that's actually driveable.
15 Dec 2021 05:02 #240655 by Lambert
Replied by Lambert on topic Diesel engine upgrade
As Busta says, it's going to be a lot of work at which point I would suggest looking at something like a Honda K series. Yes it's petrol but at 2 litres you will have more than enough torque and because its a popular swap the support is out there in terms of adapter for a suitable gearbox and sump repositioning, there's no end of readily available stand alone ecu options and tuning is easy enough. Diesel has a place but it is powering heavy things, a Jimny is light and doesn't need vast amounts of torque at 1300 rpm.
  • Podge
15 Dec 2021 10:50 #240657 by Podge
Replied by Podge on topic Diesel engine upgrade
I think it would probably be down to fuel consumption. Having a car that can't exceed 35mpg on a regular basis isn't too clever when go juice is 1.40 + a litre.
Would the Renault K9K be an easy fit due to the fact that it was fitted to some Jimnys? I suppose you'd find the longnitudinal/transverse layout being a problem.
15 Dec 2021 16:09 #240664 by Busta
Then you must factor in the cost of the conversion. At most you will save 5p/mile, so you're looking at 100,000 to break even on the cost of a £5k conversion.
16 Dec 2021 10:02 #240676 by Scimike
Replied by Scimike on topic Diesel engine upgrade
If it is running cost and you want to keep the vehicle how about an LPG kit?
Currently 50% less than petrol and you can expect a 10 - 14% decrease in your current Mpg running on LPG, you can do the maths and see if it pays.
I ran LPG on my Scimitar V6 (everyday run around) and it payed for itself within 2 years. That said I fitted and designed my own manifold system so the "install cost" was low.
May be worth investigating?
