G4 Jimny Rear Wiper Blade Replacement
14 Dec 2021 01:20 - 14 Dec 2021 01:22 #240630
by Scimike
Replied by Scimike on topic Re:G4 Jimny Rear Wiper Blade Replacement
Google suggests the Suzuki part is about £20.
shopsuzuki.co.uk/products/suzuki-jimney-...ine-rear-wiper-blade
How about changing the arm if you can't get blades or don't want to pay stupid prices.
It is after all is said and done nothing special.
Last edit: 14 Dec 2021 01:22 by Scimike.
14 Dec 2021 07:16 - 14 Dec 2021 07:16 #240632
Replied by Soeley on topic G4 Jimny Rear Wiper Blade Replacement
Over on one of the FB groups apparently these are the Bosch Aero alternatives.
AR13U from Bosch for the rear and
AR16U for the front
AR16U for the front
Last edit: 14 Dec 2021 07:16 by Soeley.
14 Dec 2021 09:35 #240633
by 300bhpton
Eurocarparts has them on offer at the mo.
The 13U is the wrong fitment however and will not work. I have a different blade for the rear, but let me go and check the rear as I haven't fitted it yet.
Replied by 300bhpton on topic G4 Jimny Rear Wiper Blade Replacement
The 16U fits the front as they are 'retro' fits. i.e. they fit the tradition hook style fitment.Over on one of the FB groups apparently these are the Bosch Aero alternatives.
AR16U for the front
14 Dec 2021 09:54 #240636
It's a private group, so no point t in me linking it, but a few responded to say they had fit them. No mention of the rear not fitting.
I thought most replacement blades came with an assortment of fitting to suit different arms nowadays.
14 Dec 2021 10:21 #240637
by 300bhpton
Ok, so the AR13U is too big really. Sorry getting mixed up. The Land Rover Defender uses 13" blades and the AR13U is indeed a retrofit and will physically fit the arm.
However they are 13" long. The factory blade is about 11 1/2 long. So the 13U will likely overhang the glass, as there isn't much of a gap.
I originally bought a Bosch A281H as it was a flatbalde of the right length. But this does indeed have the wrong fitment.
So I swapped it for a Bosch SP11 which is rated at 11"/280mm
As you can see it is ever so slightly shorter than the factory fit option:
But has the correct fitment:
Incidentally, I found it easier to move the arm upright to remove the old blade (turn wiper on, turn ignition off when in the position you want).
The swept area is slightly less with this blade, but it'll do for now. However if you look at the glass where original was, I think you'd be overlapping the paint with the 13" blade.
- Roger Fairclough
- Thank you received: 211
14 Dec 2021 11:41 #240639
by Roger Fairclough
Replied by Roger Fairclough on topic G4 Jimny Rear Wiper Blade Replacement
Front wiper blades are 400mm and rear is 300mm.
Roger
Roger
