Jimny loosing power/ not accelerating properly
07 Dec 2021 04:18 - 05 Jul 2022 23:29 #240527
by JimnyZh
Updated: Jimny loosing power/ not accelerating properly was created by JimnyZh
Newbie here but I have been driving my 2010 Jimny since I have bought it new.
I wouldn't say I religiously maintain it but at least oil change every 15000 km. The plugs were changed 20000km /10000miles ago (a year ago).clutch plates were changed at 90000km but feels ok at current 215000km so I have not had it changed.
Anyway, I have noticed that at around 90km/h (55mph), sometimes it's would not accelerate anymore for say a minute, then all of a sudden it would start to accelerate normally again (on a flat roar that I didn't have problem for years). And every now and then at 90 plus kph, I could feel the power dipped for a second (as if I let go of the gas pedal for a second) before going back to normal.
I thought it was my clutch again but if it were the case, the RPM would have gone crazy...
Not sure if it is related, the Jimny also started to stall when idle (usually it's at around700rpm, but sometimes it slowly drops to below 500 and stalls), maybe it's related or maybe just the cable stretching over time?
Any suggestions before I take it to a mechanic? I is my experience that if I knew what could be wrong, I would get charged less.
Thx
Update: 6-7-22
a few months back my mechanic told me to just get new fuel and give it a good high RPM run on the motorway, it did the trick. He thought it may be a bad batch of fuel
Thx
Update: 6-7-22
Last edit: 05 Jul 2022 23:29 by JimnyZh.
- Thank you received: 2001
07 Dec 2021 06:41 - 07 Dec 2021 06:45 #240528
Replied by Lambert on topic Jimny loosing power/ not accelerating properly
Welcome to the forum. Sounds like the early stages of the camshaft/crankshaft position sensor failing, does it usually do it once it's good and warmed up? The other alternative could be the catalytic converter disintegrating but that would be more constant.
Last edit: 07 Dec 2021 06:45 by Lambert.
07 Dec 2021 10:42 #240534
by JimnyZh
Replied by JimnyZh on topic Jimny loosing power/ not accelerating properly
Thanks Lambert
It does feel like it only does that once warmed up, but then I usually only get on the motor way after its warmed up.
I hope it's not the camshaft, that sounds expensive....
07 Dec 2021 15:48 #240541
They are sensors that tell the computer where the engine is in its cycle. They're cheap enough.
07 Dec 2021 22:17 #240546
by JimnyZh
Ah ok, so is there a way to figure out which in to change? Or do I just go ahead with replacing the one easier to get to first (I read on this forum that one is much easier to replace) and see if it works?
There are also references to "water spray test" for the sensors on this forum but I couldn't figure out how to do it and what is it for.
Thanks again
Thanks again
05 Jul 2022 23:30 #243956
by JimnyZh
JUST an update: few months back my mechanic told me to just get new fuel and give it a good high RPM run on the motorway, it did the trick. He thought it may be a bad batch of fuel
Time to create page: 0.162 seconds
