Heated seat retrofit
19 Dec 2021 00:01 #240712
Replied by yakuza on topic Heated seat retrofit
I do not like the bottom boiler. Back warmer is ok.
Hate it when i take the car and wife left the seat heat on full.
Guess it is like the toilet seat that women never ever raise after they use it.
If I push these complaints any further now I will be fired.
- thispasito
22 Dec 2021 08:35 #240733
by thispasito
Replied by thispasito on topic Heated seat retrofit
I believe the heated seat switches have LEDs in them. Do you know which wires power the LEDs inside the switch?
22 Dec 2021 19:45 - 22 Dec 2021 19:46 #240741
by fordem
Replied by fordem on topic Heated seat retrofit
The switch backlight LEDs are powered from the sidelight circuit (red w/yellow stripe), the switch "tell tale" LEDs are powered from the rear defog circuit (yellow w/green stripe).
Last edit: 22 Dec 2021 19:46 by fordem. Reason: Correction
- thispasito
23 Dec 2021 09:02 #240747
by thispasito
Thanks fordem, if the switches are not installed, is the red w/ yellow wire connected to anything? Can I just cut it and connect to my LED strip?
Time to create page: 0.832 seconds
