Lockers
24 Oct 2021 19:08 #239604 by Busta
Replied by Busta on topic Lockers
Roger.
You said it would double or triple the turning circle. I have demonstrated that it doesn't.
You said the vehicle would only drive in a straight line, I have demonstrated that it doesn't.
You said that driving would be difficult. I have demonstrated that it isn't.
You said that the vehicle would buck around. I have demonstrated that it doesn't.
You said that something will break. I have demonstrated that it doesn't.
9.8m is the turning circle in 2wd. No Jimny will turn that sharp in 4wd. I can measure it if you'd like? Or I can make another video comparing directly with a standard Jimny in 4wd. I can also demonstrate how the engine loads up just the same without a welded diff, which is normal when using 4wd  while turning sharply on a relatively grippy surface. You should be aware of this, as you say you noticed the steering weighting up when using your "LC" in 4wd on grippy surfaces. It's the same thing.
I have a Quaife LSD fitted in the rear, which is a helical gear LSD just like the Truetrac you had back in the day (not available for a Jimny).
We could compile a list of popular modifications that contravene construction and use regulations. It would be quite long. As discussed many times before, using 4wd on a sealed surface is not on my agenda, no should it be on anyone else's. It is potentially dangerous even in a completely standard vehicle.
Your second post describes exactly how the 4wd system on a standard Jimny can be used, with a simple push of a button or flick of a lever at a moments notice. No conversion needed.
The topic has been locked.
24 Oct 2021 19:47 #239608 by Lambert
Replied by Lambert on topic Lockers
This thread is now closed before it starts getting personal.
The following user(s) said Thank You: mlines
Time to create page: 0.856 seconds
