Re:Gen3 warning buzzer modulation
- Thank you received: 2004
04 Sep 2021 10:39 #238205
Gen3 warning buzzer modulation was created by Lambert
Has anyone successfully modulated the warning beeper on a gen3 and if so how? A continuous tone for the lights on with the keys out is one thing but then there's a beeping for keys in accessory and door open a different beeping for engine on door open and another different one for no seatbelts above 5 mph. It's like being on a piggery unit at feeding time everything SCREAMING AT ME TO DO SOMETHING! So I was just wondering if there is a way to maintain the flashing lights on the dashboard but quieten down the noise? On Dreadnaught there was no seatbelts warning and the ignition was on a separate connector that could be isolated but in Temeraire it seems that the individual connector is now part of a bigger loom so not as simple to remedy.
06 Sep 2021 09:40 #238273
by RainerK
Replied by RainerK on topic Gen3 warning buzzer modulation
Hello,
I disconnected the plug in the steering wheel faring so that there is no „key in and door open“ beep and I disabled the safety belt beep. Both are quite easy to do and I live with the rest.
06 Sep 2021 11:34 #238277
Replied by Lambert on topic Gen3 warning buzzer modulation
I did that on my 2011 but the same connection is not in the same place on my 2018. I will have a look around the ignition tumbler when I'm home. Thanks.
- lookonimages
- Thank you received: 72
06 Sep 2021 12:29 - 06 Sep 2021 12:36 #238281
by lookonimages
Replied by lookonimages on topic Re:Gen3 warning buzzer modulation
Lambert is that gen3 or gen 4
On gen4 there is wiki article for engine in ignition door open beep. I have done this.
www.bigjimny.com/mobiquo/redirect.php?pid=224625
On gen3 here is what I did on my previous jimny.
www.4x4community.co.za/forum/showthread....=4090049#post4090049
This whole thread is about gen3 beeping. First ones to last ones and differences in wire looms and connectors.
Hope it might help you. My gen3 was 2016/17 so maybe could be same as 2018
Last edit: 06 Sep 2021 12:36 by lookonimages.
- lookonimages
06 Sep 2021 12:41 #238282
by lookonimages
Lambert you can easily test with globe between - and the wire while door is open and key in ignition to confirm the brown wire as the key in ignition indicator.
06 Sep 2021 16:11 #238290
Replied by Lambert on topic Re:Gen3 warning buzzer modulation
Temeraire is as far as I can tell one of the very last gen3s. I'll look at the link later cheers.
Time to create page: 0.135 seconds
