Discreet front tow points.
14 Aug 2021 20:01 #237554 by Lambert
On my travels through YouTube (I blame binky) the idea has presented itself to make or adapt a set of front recovery points that accept the large screw in eye bolts most cars usually have have one of. The idea would be to only use with a bridal to minimise the loading. The advantage would be that when not in use there wouldn't be any ugly protruding metal in the bumper just a couple of grommets. The way I have seen it done involves using coupler nuts appropriate to the eye bolts welded securely top and bottom along their length, which for m16 is best part of 30mm of weld on 2 sides so reasonably unlikely to fall off with much less than 2 tonnes per side and if a Jimny needs 4 tonnes of force to get free damage elsewhere is highly likely. The only other issue is that the correct post 2014 donor recovery points are on back order and I don't know how adaptable the older style ones I have in stores would be for the ends of Temeraire's chassis.
Do we think this is a viable solution or would it collapse first time it was used in anger?
14 Aug 2021 21:54 #237556 by gv42
Replied by gv42 on topic Discreet front tow points.
Have look at DAVE MARSH RACING on EBAY
15 Aug 2021 08:17 #237559 by Scimike
Replied by Scimike on topic Discreet front tow points.
I actually believe its a viable solution and if built correctly will not cause any issues. To this end you need to decide if your welding is good enough or it's time to pay a professional coded welder to "glue" it all together.
You could also investigate using manufacturers tow point hardware / ideas, rob it off scrap vehicles and adapt accordingly.
If I had a need myself for front tow points this is the route I would also go down. Good luck.
15 Aug 2021 09:11 - 15 Aug 2021 09:13 #237563 by Quasi
Last edit: 15 Aug 2021 09:13 by Quasi. Reason: One day I'll learn to type
15 Aug 2021 10:21 #237564 by Lambert
Replied by Lambert on topic Discreet front tow points.
Yes something like that but without the weight of the box section for the centre mount.
I was thinking to use existing eyes off something heavy like a discovery. Initially I have to work out if the bolt on parts I already have can be used.
15 Aug 2021 12:37 - 15 Aug 2021 12:38 #237565 by lookonimages
Quasi wrote: Something akin to this?
Great ideas
Last edit: 15 Aug 2021 12:38 by lookonimages.
Time to create page: 0.249 seconds
