Front prop shaft replacement - new or old
  • Smiffy1664
12 Aug 2021 09:49 #237506 by Smiffy1664
Front prop shaft replacement - new or old was created by Smiffy1664
Hello fellow Jimny lovers, any advice in the following matter would be really appreciated. My front prop shaft is knackered (spewing grease and can't be fixed / reconditioned apparently) so I'm now faced with do I get a used one to replace it or spend mega bucks on a new one? Both options seem to be difficult to source for some reason!? What I want to know is (1) is a second hand one too risky to be spending up to £400 all in (part & work) and if not, any one got any idea where to get one? (2) anyone know where to get a new one in the UK that isn't made by Suzuki but is fit for purpose? My Jimny is a 2005, soft top, 1.3, O2 model. The propshaft part is 2710384A00. Thanks
12 Aug 2021 21:57 #237521 by j999pre
I sell new HD ones or have standard used ones for sale
Grey pick up Jimny
  • Smiffy1664
12 Aug 2021 22:16 #237522 by Smiffy1664
Replied by Smiffy1664 on topic Front prop shaft replacement - new or old
Hi there? How much for either and how do I buy from you?
13 Aug 2021 03:30 #237523 by mlines
The UJ's can be replaced. Also a good propshaft company can sort them such as Bailey Morris who have local branches around the country. I have had a couple done by then. You say "spewing" oil, there is hardly any grease in them?
Sent from my moto g(8) power using Tapatalk
13 Aug 2021 07:21 #237524 by Busta
Firstly changing the front prop is a 10 minute job so labour charges should be minimal.
Is it spewing grease from the greasabe end? If so, has it been over greased? That's not a reason for failure. Unless there is play in the joints it's not a reason to replace.
Front props don't tend to wear very much because they are only spinning when you are in 4wd and for most users this is fairly infrequent.
As Martin says, UJs can be replaced. This is a fiddly job but still shouldn't take a mechanic long.
Fitting a used prop should also be fine for the above reasons- it is unlikely to have seen much action.
I'd say the first step is to get a second opinion before throwing £400 at a £100 problem.
  • Smiffy1664
13 Aug 2021 09:53 #237529 by Smiffy1664
Garage have now found a used prop shaft and are fitting it today! I feel much better about going for the used option after all your good advice. Many Thanks!
Time to create page: 0.345 seconds
