Jimny That Wasn't Starting....
28 Apr 2021 10:32 #234743
by Doo
Has anyone see the plot?
Jimny That Wasn't Starting.... was created by Doo
Hi all, I posted a while ago about a friends Jim that wasn't starting after having it's engine re-installed.
We checked everything over & over, made new wires & connections for the corroded ones, checked every fuse over and over, but still nothing.
I knew I had to see the MIL and the immob lights before she would start, so I went through everything again. Stumped!
I decided to remove the two relays under the bonnet and test them. Sure enough, 96 ohms for the coils, but nothing on the switches! So I hooked each one up to a big battery and ran another test. At first, the (first) relay clicked on and off in a chattering motion, then settled down and stayed "made" until I disconnected the battery. I tested it over and over, sure enough it was now showing that there was current passing through the switches. So did the same with the 2nd relay and it also chattered before settling down and it too showed power was flowing.
So I kept them naked (I removed the rubber cover then the plastic shell to expose the innards so I could inspect them closely) and re-inserted them into my friends Jim. I asked him to switch on the ign and look for the two yellow lights... As he switched on, I heard the fuel pump relay click and fuel flow through the fuel rail. I knew she'd start. He confirmed the yellow lights and she fired up immediately
So all along, these relays had been playing, but not! I cant say with any certainty if putting them on the higher amp battery frightened them into life, but I can say the car is running and my friend is delighted (or with the presence of the two missing dash lamps should that be "re-lighted" ).
So I figured you guys needed this info in case, like us, you have someone tearing their hair out with a simple, but infuriating non start issue
Thanks all.
Thanks all.
28 Apr 2021 13:20 #234745
by Gadget
Replied by Gadget on topic Jimny That Wasn't Starting....
I love posts like this with interesting troubleshooting titbits. I may never need the info, but always useful to have, thanks
- petejones69
11 May 2021 17:33 #234980
by petejones69
Replied by petejones69 on topic Jimny That Wasn't Starting....
This could be what is afflicting mine - checked everywhere for mouse nibbles in the wiring and no breaks as far as I can tell. The fuel pump doesn't start nor does the relay fire; the amber engine warning light doesn't come on when I turn the key in the ignition.
Time to create page: 0.203 seconds
