Gen 4 tow bar
13 Feb 2021 19:19 - 13 Feb 2021 19:20 #232756 by lightning
Gen 4 tow bar was created by lightning
l want to fit a detachable tow bar to our 2020 Jimny.
Am l best off fitting the Suzuki one? (at nearly £400) And l know l will need the electrical socket but is the wiring harness fitted in the vehicle or does it need a complete fitting kit.
ls this something l could fit myself? l've done it on the Defender, there was an electrical plug behind the chassis at the rear for the tow bar harness to plug into.
Last edit: 13 Feb 2021 19:20 by lightning.
13 Feb 2021 20:39 #232758 by Dan
Replied by Dan on topic Gen 4 tow bar
I think this chap who did a video on gen 4 towbar fitting might have mentioned he was a member on here.
13 Feb 2021 22:29 - 13 Feb 2021 22:35 #232760 by Scimike
Replied by Scimike on topic Gen 4 tow bar
Hi
Fitting a tow bar on any vehicle is not a challenging Job, they simply bolt into place, a bit like a large meccano kit. The worse bit is the electrics which require you to splice into the correct cables, or if you are lucky, simply plug into a ready made socket.
You need to get the rear wheels on ramps just for clearance, but after this it's basic tools.
Could you do it yourself?
Yes I am sure you could, not much difference to the Defender. I did remove the rear bumper on my G3 when I fitted ours, simply to let me adjust the exhaust silencer which sat a little too close for my liking to the new steelwork.
It's down to if you feel like spending a few hours under or around the rear of the vehicle and have the basic tools (and inclination) to do it.
I would expect the OEM Suzuki unit to fit perfectly and the electrics to be plug in at that sort of money.
Nothing wrong with reputable third party tow bars, and you can usually get a fully fitted price for these if you don't fancy it yourself.
I personally have never fitted the manufacturers towbar offering, simply too much for my shallow pockets. I don't know what you can get for the G4, Suzuki's may be your only options. But even if it was I would still fit it myself as I trust very few to work on my vehicles.
Last edit: 13 Feb 2021 22:35 by Scimike.
14 Feb 2021 11:40 #232768 by Roger Fairclough
Replied by Roger Fairclough on topic Gen 4 tow bar
As part of the deal, I had a genuine Suzuki tow bracket kit fitted to my Gen.4 prior to purchase, so I have listed below a few points of interest.
1) The electrics are 13 cable so a power point from the fuse box located in the passenger footwell is required. If you are towing a trailer or caravan or just want to mount a bike rack you will need to fit 13 cable plugs.
2) All legal tow bracket kits will have detachable tow balls because the standard 2 bolt design would partially block the number plate and that is illegal.
3) The swan neck appears to be excessively long but it is so to extend the ball past the spare wheel.
I would assume that Scimike comment re: plug in electrics is correct but I failed to ask for the fitting leaflet, although I noticed that the power supply plug. when fitted did not allow the fuse box cover to be fitted!
Roger
14 Feb 2021 11:55 #232770 by Lambert
Replied by Lambert on topic Gen 4 tow bar
All my trailers are 7 pin as is Dreadnaught but Leviathan is 13. Fortunately there are adapters readily available to allow 7 pin trailers to work on 13 pin cars. As I understand it the 13 pin is an mot item but the 7 isn't. I think the 13 came about because of caravan users not being able to be relied upon to remember to plug in 2 7 pins. We did look at having a 7 pin fitted to Leviathan but apparently the bcm would not be a happy bunny?
14 Feb 2021 16:21 - 14 Feb 2021 16:24 #232775 by Foxtrot
Replied by Foxtrot on topic Gen 4 tow bar
From my experience I  would advise you use the Suzuki towbar and the Suzuki harness. I took my GEN4 to a towbar specialist, however they hadn't fitted one before so they used their usual supplier which was Brink, he advised me to use the correct harness because the car was new and a generic one could invalidate  warranty.
Anyhows as it turned out the after market towbar was too short and I could not fit my ALKO  hitch without taking my spare wheel off as the ball was under the tyre, the Suzuki one is specifically made to clear the spare tyre. They had to order me a Suzuki one and change it out as  the Brink "wasn't fit for purpose".
you can see the difference with the two pictures, below is the Brink and below that is the Suzuki.
Last edit: 14 Feb 2021 16:24 by Foxtrot.
Time to create page: 0.197 seconds
