Re:Steel rims
- Lasse
25 Jan 2021 18:13 #232177
by Lasse
Steel rims was created by Lasse
hey everyone
What ET number can be fitted to a gen 4 with a 2" lift without the tyres are rubbing against something.?
thanks ..
thanks ..
25 Jan 2021 18:26 #232178
Replied by mlines on topic Re:Steel rims
Depends on the tyres as much as the rims
- Lasse
25 Jan 2021 22:17 #232183
by Lasse
Replied by Lasse on topic Re:Steel rims
Thinking 215/75-15
The 235 is given a lot of smoke for being to big and make the car slow - but looks pretty awesome with the big Tyres..!
- Thank you received: 2001
26 Jan 2021 05:02 - 26 Jan 2021 05:04 #232192
Replied by Lambert on topic Re:Steel rims
Couple of assumptions the tyre is not a remoulded one and also is not a massive tread extreme type. Then the standard 5.5j et5 15 inch wheel will accommodate a 215.75 on standard height suspension. An after market wheel is most likely going to be wider so 6j or 7j and is probably going to be either et0 or a negative et and combining the two will possibly cause rubbing but how much is contingent on the age and condition of the suspension and how much it has settled over time.
Last edit: 26 Jan 2021 05:04 by Lambert.
- B3Hulk
03 Feb 2021 09:49 #232438
by B3Hulk
Replied by B3Hulk on topic Re:Steel rims
Negative 13 offset with 215/75/r15 no rub with it flush against the body.
Time to create page: 0.147 seconds
