Jimny making a new sound
- Brendan
20 Jan 2021 09:13 #231975
by Brendan
Jimny making a new sound was created by Brendan
Hi, my 2006 Jimny has started whirring at me above 2000RPM. Initially I thought transfer case, because it actually sounds like using 2WD-L, however it's coming from the front end, it's maybe worth mentioning too that this particular car has a appetite for serpentine belts, and has had 3 replacement belts and a new Crankshaft pulley. The transmission feels sturdy and doesn't miss a beat however the clutch is on its last legs.
Any ideas??
Here's a video:
Any ideas??
Here's a video:
- Thank you received: 626
20 Jan 2021 13:53 #231989
Replied by DrRobin on topic Jimny making a new sound
Have you had a new belt since the crank pulley was changed? Was it both belts or just one?
20 Jan 2021 14:40 #231991
Replied by mlines on topic Jimny making a new sound
Alternator (does it change if you turn headlamps off/on)
The failure of Alternator bearings is a secondary cause of belt failure.
- Brendan
20 Jan 2021 17:27 #231996
by Brendan
Replied by Brendan on topic Jimny making a new sound
Yes, both new belts, and prior to that, a new alternator.
- Thank you received: 1934
20 Jan 2021 18:27 #231999
Replied by Lambert on topic Jimny making a new sound
Is the fan and shroud intact and secure?
Time to create page: 0.328 seconds
