Wet, soggy smelly interior's..!
08 Jan 2021 02:41 #231587
by Seanhart
Wet, soggy smelly interior's..! was created by Seanhart
Hi all,
Gen 4 has a great "rain gutter" all around the roof ..
On the Gen 3 there is nothing, so,.. when it is raining and and you open the door all the water ends up inside on the floor. We end up with soggy smelly carpet.. I'm in the Philippines so lets add humidity to this equation and in the end it all stinks.!
Has anyone seen/come-up-with or found some way to remedy this...
I would be SOOOOO... greatful..?
- Thank you received: 1963
08 Jan 2021 06:44 #231591
Replied by Lambert on topic Wet, soggy smelly interior's..!
We have plenty of rain here too but it's much cooler so having the heating on helps to dry it up. I aren't aware of any off the shelf solutions beyond carrying out a few strategically placed bags of silica gel crystals like you get in packaging to absorb the moisture, dry rice will work too.
- Roger Fairclough
- Thank you received: 223
08 Jan 2021 09:36 #231597
by Roger Fairclough
Replied by Roger Fairclough on topic Wet, soggy smelly interior's..!
Ultimate solution is to remove the carpets and leave the floor bare or cover with rubber or plastic matting.
Roger
Roger
08 Jan 2021 09:44 #231599
by Bob1050
Replied by Bob1050 on topic Wet, soggy smelly interior's..!
An alternative option might be - source an extruded and flexible 'U' shaped rubber channel/seal plus some outdoors type double-sided sticky tape - and apply to the bodyshell above the doors? I'd wager that there's an appropriate channel that could be re-purposed to suit your application.
- Thank you received: 923
08 Jan 2021 10:41 #231605
Bed-liner!
The first thing I do when I start any Suzuki project is rip the carpets out and throw them away! :laugh:
Replied by X8GGY on topic Wet, soggy smelly interior's..!
Or...Roger Fairclough wrote: Ultimate solution is to remove the carpets and leave the floor bare or cover with rubber or plastic matting.
Roger
Bed-liner!
08 Jan 2021 12:33 - 08 Jan 2021 12:36 #231611
by Scimike
Replied by Scimike on topic Wet, soggy smelly interior's..!
Same problem if you have a caravan, so they make a stick on rain channel in various lenghts.
Google Search for:-
Fiamma Drip Stop Gutter Door Rain Deflector
Its expanding Bod1050's suggestion into a pre made product.
Ebay Example
ebay.us/J3GWkd
Google Search for:-
Ebay Example
ebay.us/J3GWkd
Last edit: 08 Jan 2021 12:36 by Scimike.
The following user(s) said Thank You: Seanhart
Time to create page: 0.309 seconds
