Vibration
  • Craigyh1990
18 Dec 2020 20:04 #231003 by Craigyh1990
Vibration was created by Craigyh1990
Newbie has it a few weeks never noticed it in way home but last couple days felt slight vibration at around 50 in the steering wheel it goes as accelerating no play leaks or weaps in the wheels at all they had tyres done before I got it and I found a receipt out for two wheel repairs one you can see it was hit relatively hard big lip on it wondering if Balancing is out or buckled rim any suggestions thanks just curious to why only just noticed it tho
18 Dec 2020 21:15 - 18 Dec 2020 21:19 #231006 by Scimike
Replied by Scimike on topic Vibration
Hi,
Is the steering wheel moving (oscillation) at about 48mph or is it stationary and you can feel (not see) a vibration?
The Jimny is susceptible to steering wobble between 45 to 50mph, usually due to failing Kingpin bearings, but a vibration may be due to something else.
Just trying to clarify the symptoms.
But as you have potential wheel damage lift each front wheel and turn it by hand and check the tyre runs true on the rim. You can get damaged tyres / rims that are balanced, but the tyre tread does not run central, causing oscillation or vibration.
Mike
Last edit: 18 Dec 2020 21:19 by Scimike.
  • Craigyh1990
18 Dec 2020 22:48 #231007 by Craigyh1990
Replied by Craigyh1990 on topic Vibration
The wheel moves with vibration yes I drive 80 miles back home when I got the car and was doing higher speeds and did not notice it at all sort of just come on a couple weeks I’ve had the car now
18 Dec 2020 23:05 - 18 Dec 2020 23:10 #231009 by Scimike
I guess it makes sense to get the wheels checked and balanced first, but if it's a 48mph vibration it's likely to be the kingpin bearings.
But start simple and check the suspension components, steering ball joints and wheels for any further unseen damage.
Don't know if you have seen this similar topic started by Helsey, does it sound like the same issue?
www.bigjimny.com/index.php/forum/6-jimny...advice-wanted-please
Last edit: 18 Dec 2020 23:10 by Scimike.
  • Craigyh1990
18 Dec 2020 23:24 #231011 by Craigyh1990
Ok il have to get it looked at thanks for your reply I did have a little look at the link mines now and then comes and goes but around the 50mph marks is only time I have noticed it maybe that’s why I never noticed it before might be on there way out and doing it some times and not other times Im not hands on like that so would have to get a garage to sort it sound expensive from what reading up in the link you sent over
19 Dec 2020 00:08 - 19 Dec 2020 00:11 #231012 by Scimike
In the world of modern cars Kingpin bearings are not that expensive to fix. You are looking at about £50 per side in parts (Suzuki quality) and about 3 - 4 hours time to change both, maybe less if the garage is use to 4x4s. I appreciate that if cash is tight anything is expensive, but it's not a bad DIY job.
If it's very slight you can mask the wobble with a steering damper kit, about £60 from eBay and a very easy DIY fit, about 1/2hr with no special tools, just a few spanners.
Last edit: 19 Dec 2020 00:11 by Scimike.
Time to create page: 0.114 seconds
