Steering Damper
07 Dec 2020 15:01 #230730 by Martinm
Steering Damper was created by Martinm
Hi All,
I am having trouble locating a return to centre steering damper in the uk, can anyone advise me were I may be able to purchase one.
In anticipation Martinm
07 Dec 2020 17:36 #230735 by Riccy
Replied by Riccy on topic Steering Damper
Hi Martin.
I bought a terrafirma one designed for a defender which fits pretty well using some home made brackets and does what it says on the tin. Damper/spring setup was about £65 i think from ebay. Model TF835.
I have taken it off recently however and havent felt the need to put it back on yet. The return to centre spring is a bit odd at first as it will centre even when not moving and all a damper really does is mask another problem on the car (i.e. worn kingpins/wheel bearings/steering rods/panhard, etc)
The following user(s) said Thank You: Martinm
07 Dec 2020 18:13 - 07 Dec 2020 18:13 #230737 by Scimike
Replied by Scimike on topic Steering Damper
Assuming you simply want a damper, at what point in the potential suspension modification chain do you need a RTC damper?
I only ask out of interest as I have a standard (LR Defender) damper on my unmodified GEN3 and the steering is just fine, no need for RTC assistance.
Is it tyre size or lift that make the difference, anyone know?
Last edit: 07 Dec 2020 18:13 by Scimike.
07 Dec 2020 19:10 #230741 by Lambert
Replied by Lambert on topic Steering Damper
Rtc is of debatable importance on a Jimny even a big one with huge tyres. A better solution is to size the wheels and tyres so they don't drastically screw up the scrub radius, that way the tyres don't offer more resistance than necessary. It's not impossible to have big tyres and nice light steering.
The following user(s) said Thank You: Scimike
07 Dec 2020 20:15 #230742 by lightning
Replied by lightning on topic Steering Damper
l've got an RTC steering damper on my Defender 110 and it's an improvement for road use as it makes the steering self centre better.
lt also improves matters on the motorway, with no need for constant steering correction.
Off road l can't really tell any difference, but l only have the standard wheels and tyres.
The Defender 110 is a large and heavy vehicle.
Not sure it would be needed at all on a Jimny, unless you are running monster wheels/tyres on it.
The following user(s) said Thank You: Scimike, Martinm
08 Dec 2020 11:09 - 08 Dec 2020 12:44 #230751 by 300bhpton
Replied by 300bhpton on topic Steering Damper
lightning wrote: l've got an RTC steering damper on my Defender 110 and it's an improvement for road use as it makes the steering self centre better.
Not wanting to sound confrontational. But I think there might be something wrong with your Defender if a return to centre steering damper makes it drive better on the motorway.
I suspect you have a more serious issue to address, that the damper is simply hiding. Else if it was that simple to change motorway behaviour, Land Rover would have fitted return to centre dampers on factory models. And they never did. Not even on the more road biased Discovery and Range Rover offerings, which all use essentially the same steering setup.
Last edit: 08 Dec 2020 12:44 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
