Steering Damper
I am having trouble locating a return to centre steering damper in the uk, can anyone advise me were I may be able to purchase one.
In anticipation Martinm
I bought a terrafirma one designed for a defender which fits pretty well using some home made brackets and does what it says on the tin. Damper/spring setup was about £65 i think from ebay. Model TF835.
I have taken it off recently however and havent felt the need to put it back on yet. The return to centre spring is a bit odd at first as it will centre even when not moving and all a damper really does is mask another problem on the car (i.e. worn kingpins/wheel bearings/steering rods/panhard, etc)
I only ask out of interest as I have a standard (LR Defender) damper on my unmodified GEN3 and the steering is just fine, no need for RTC assistance.
Is it tyre size or lift that make the difference, anyone know?
- Thank you received: 2005
lt also improves matters on the motorway, with no need for constant steering correction.
Off road l can't really tell any difference, but l only have the standard wheels and tyres.
The Defender 110 is a large and heavy vehicle.
Not sure it would be needed at all on a Jimny, unless you are running monster wheels/tyres on it.
Not wanting to sound confrontational. But I think there might be something wrong with your Defender if a return to centre steering damper makes it drive better on the motorway.lightning wrote: l've got an RTC steering damper on my Defender 110 and it's an improvement for road use as it makes the steering self centre better.
I suspect you have a more serious issue to address, that the damper is simply hiding. Else if it was that simple to change motorway behaviour, Land Rover would have fitted return to centre dampers on factory models. And they never did. Not even on the more road biased Discovery and Range Rover offerings, which all use essentially the same steering setup.
