Not Jimny related - question for mechanics
29 Nov 2020 08:18 #230491 by me101
Morning all. Not a Jimny question, but just looking for any thoughts. The wife has a 208 GTi which has a 1.6 turbo unit, and although it generally drives fine, there is an issue when you put your foot down. Still under warranty, but dealer says they cannot find an issue (which to me means they plugged it in and nothing came up). Best way I can describe it, is it surges. When you accelerate hard, it is not a smooth power delivery, it feels like it comes in waves. Had numerous turbo motors before, never had an issue like this. Any thoughts on what might be the problem??
Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
29 Nov 2020 10:19 #230493 by Scimike
Not going to be much help unfortunately, but start simple and inspect the entire air duct circuit within the turbo system. An air leak on both the input and output side of the turbo can impact the way it performs.
After this it gets more difficult, it could be anything!
I assume this surging is not normal for the GTI, any forums or Facebook pages with owners experience you can ask?
After this I can only think rolling road engine tune. These people have the equipment to look at the performance of the entire system and are likely to spot the issue, you may even get a few more bhp in the tune.
Good luck
Mike
29 Nov 2020 10:40 #230494 by Lambert
Could be air flow monitoring related or vacuum/pressure control system related. Or it could just be because it is French and taking industrial action?
29 Nov 2020 10:51 #230495 by me101
Doesn't seem to be a common issue on these, and looked at upping the BHP but seems they don't take kindly to it. Currently putting it down to French crap - she has had a couple of Fiat Punto turbos in the past, so we know sometimes to just overlook certain things!! Will have a look at the air pipes in the next few days.
Cheers
30 Nov 2020 07:38 #230518 by Grim Reaper
Try a Mass Air Flow sensor clean with some proper spray cleaner.
The dealer should have been able to see data from the sensor on their OBDII gear to see if it is acting up, but they may just want to get you to take it in when it eventually breaks down so they can charge you for replacing it.
(Cynical? Moi!)
  • Jimx5
30 Nov 2020 08:48 #230520 by Jimx5
Replied by Jimx5 on topic Not Jimny related - question for mechanics
You may well find there is nothing wrong with it.
My last two vans and both my son's vans do the same.
They drive as normal but the accelerator pedal has a bit of resistance 3/4 of the way down, when you press the pedal past the resistance the turbo kicks in, it's like a kick down switch.
Imagine you are entering a roundabout and miss-judged the traffic speed coming from the right and the engine has bogged down, you'd press the pedal down further than you normally would to get out of trouble this is where you'll the usefulness of this function especially in 2nd gear, and it can take you by surprise.
Most new diesel cars have this function.
Time to create page: 0.322 seconds
