Gen 4 replacement radio
  • Pspies
21 Oct 2020 21:27 #229369 by Pspies
Replied by Pspies on topic Gen 4 replacement radio
At a basic level yes, all of the individual elements do work.
My primary issue is that on start up the unit defaults to the radio function. This is irritating enough if you are in range of a radio station and get blasted with tunes. It get far more annoying if you are off road in the bush and out of range of a radio station, then you get blasted with a load hiss/crackle. Even less fun when you are parked two feet from an elephant :ohmy:
I never use the radio function. Only Bluetooth or CarPlay. Never have this problem in my other/previous vehicles.
Slightly less annoying is that the unit resets the call volume after a call.
  • GeorgeC
21 Oct 2020 21:39 - 21 Oct 2020 21:57 #229370 by GeorgeC
Replied by GeorgeC on topic Gen 4 replacement radio
The old advice of RTFM, the Folding Manual may be better replaced by RTPDFM, a newer PDF Manual, you can download manuals from here: www.suzuki-slda.com/_layouts/15/start.as.../Forms/AllItems.aspx There will be a method in the South African Manual to mute the radio. We have the same problem here, spooking the Kangaroos and Koalas.
EDIT: Sad news, no South Africa Manual on that page!! :( I will keep looking...
Last edit: 21 Oct 2020 21:57 by GeorgeC.
  • Pspies
21 Oct 2020 22:04 #229372 by Pspies
I have RTFM’d the radio manual that came with the car to death.
From what I can tell, I can only mute the entire unit and not just the radio function ?
  • GeorgeC
21 Oct 2020 22:27 - 22 Oct 2020 02:53 #229374 by GeorgeC
My son, a phone geek, suggests the radio volume may be able to be re-set or muted from the phone before shutting down the car. :unsure:
Matching the Manual to the Software Version will also help, so try a PDF Manual download from another Country with a 17** Firmware Version such as AUS/NZ (Region 10) or India (Region 1), the base programs for them are from the same source, Maruti.
This Forum may have some useful information: www.team-bhp.com/forum/car-entertainment/
Last edit: 22 Oct 2020 02:53 by GeorgeC.
22 Oct 2020 09:07 #229387 by lookonimages
Pspies wrote: I have RTFM’d the radio manual that came with the car to death.
I just put radio volume to zero. Not using the mute. That way when i put radio on it is at zero level. If i need to listen to music i crank up volume.
Having radio at lowest level do no influance level of phone etc.
Radio permanent on zero level when in the bush and all other sounds like phone still work as normal. Work pefectly for me.
The following user(s) said Thank You: GeorgeC
22 Oct 2020 09:34 #229389 by saxj
Replied by saxj on topic Re:Gen 4 replacement radio
It is very irritating that you can't just turn off the radio.
I also found that the generally more useable replacement for Google Play Music, You Tube music, doesn't work at all when you don't have cellular reception. So in some parts of South Africa you have to drive in silence (or static).
Time to create page: 6.710 seconds
