Speedo sensor needed
  • stoneuk
21 Oct 2020 10:06 #229337 by stoneuk
Speedo sensor needed was created by stoneuk
Hi, Can anyone help me please .. I've been told i need a speedo sensor that is located on the gearbox . I have 1.3 Jimny 2002 auto . Thanks
  • X8GGY
21 Oct 2020 16:07 #229350 by X8GGY
Replied by X8GGY on topic Speedo sensor needed
Hi... it's on the transfer box, not the gearbox..
Martin (this is his discussion board and store) can probably get you a new one, or a breaker (on eBay?) could supply a second-hand one...?
What's wrong with yours?...
21 Oct 2020 16:13 - 21 Oct 2020 16:13 #229351 by mlines
Replied by mlines on topic Speedo sensor needed
I guess the price is the reason Steven is asking here - its £165 for a new one I quoted this morning
I would check the wiring first at that is what normally fails.
Interestingly enough, Suzuki have a different part numbers for the sensor fitted to Autos and Manuals (despite it fitting to the transfer case) so I am not sure you could use one from a manual car.
Last edit: 21 Oct 2020 16:13 by mlines.
The following user(s) said Thank You: stoneuk
  • stoneuk
22 Oct 2020 11:14 #229391 by stoneuk
Replied by stoneuk on topic Speedo sensor needed
Hi, Thanks for getting back to me .. He electrical guy said he "Thinks" it's the problem as to why i've not any movement on the speedo .. (The odometer is working fine)
I'll be honest and say that a second hand one would be the best bet as a new one could work out expensive if it's not cured afterwards .. Thanks
23 Oct 2020 20:58 #229439 by kirkynut
Replied by kirkynut on topic Speedo sensor needed
stoneuk wrote: Hi, Thanks for getting back to me .. He electrical guy said he "Thinks" it's the problem as to why i've not any movement on the speedo .. (The odometer is working fine)
I disagree with the electrical guy as how can the odometer be working if the sensor isn't? My old 2000 model has no abs, so the only thing counting revolutions of anything speed wise is that sensor. It therefore has to feed the odometer and speedo.
I'd suggest that the issue is in the speedo itself or the wiring to it.
24 Oct 2020 13:00 #229452 by jackonlyjack
Replied by jackonlyjack on topic Speedo sensor needed
I have to agree with Kirky
When i first fiited my sj box sensor wasn't sat correct and no miles where being added
Speedo needle used to jump around
But when it was showing speed miles where adding
I have a spare sensor somewhere from a manual
Time to create page: 0.099 seconds
