will a little pressure ruin the vacuum system?
- seannd24
23 Aug 2020 09:48 #227194
by seannd24
will a little pressure ruin the vacuum system? was created by seannd24
Hi everyone.
i'm a brand new member here so thank you for having me. especially a big thank you to Martin for his wise advice yesterday.
i am about to purchase my first jimny in a couple of days time knowing that it has a 4wd problem in that it will not engage 4wd high or low and there is a permanent flashing green symbol on the instrument panel ( twice a second ) that remains on even when restarting the car ( 06 plate but it's very low mileage and full history etc so i'm not overly concerned. )
my question to you all is: would it do any damage if i slightly pressurise the vacuum system in order to search for any leaks using soapy water?
thank you all in advance. .
23 Aug 2020 10:17 #227196
Replied by mlines on topic Re:will a little pressure ruin the vacuum system?
It will be fine but do not over do it as you could blow the seals in the hub
The following user(s) said Thank You: seannd24
23 Aug 2020 10:23 #227197
by Scimike
Replied by Scimike on topic Re:will a little pressure ruin the vacuum system?
Already answered by Martin, I plan to do the same if my system ever fails.
So only thing left is to say hello.
Mike
Mike
23 Aug 2020 10:55 #227198
If it helps the vacuum system works at a vacuum of 260 mmHg or greater (ie, thats the vacuum that pulls the hubs in/out of lock)
260 mmHg is around 5 PSI (of vacuum)
23 Aug 2020 12:58 #227201
by Busta
Replied by Busta on topic will a little pressure ruin the vacuum system?
Please let us know how you get on. I'd always though that a bit of pressure would be an easy way to find a leak, but in my 7 years of Jimny ownership I haven't yet had an opportunity to try it!
23 Aug 2020 13:12 #227203
by mxman
Replied by mxman on topic will a little pressure ruin the vacuum system?
I actually bought a 2002 Jimny a month ago that has the piping to engage the 4wd completely rusted out.
I bought the parts and the dealership advice me also to change the seals on the front hubs, so I am quite interesting in know how it works for you before opening the hubs.
Time to create page: 0.215 seconds
