Re:Re:Driving lights and foglights. Versions over world
- lookonimages
- Thank you received: 72
14 Aug 2020 22:02 - 14 Aug 2020 22:25 #226674
by lookonimages
Driving lights and foglights. Versions over world was created by lookonimages
Was about to order a set of daily driving lights led from martin.
Our foglights are just foglights. Only one bulb
Daily driving light is part of main lights and is already "led"
Only daulight running lights are switch on and no foglight.
If you set daylight driving lights "on" there is about a sqaure at the botom section of main light that lights up as "daily driving lights." Foglights will be off
Daily driving light on and foglights on, then the square block light up as well as the two foglights in the bumper section.
If you put on the mainlights, the mainlight turn on and square area turn off
Just thought it is interesting to see the difference.
Last edit: 14 Aug 2020 22:25 by lookonimages.
- GeorgeC
15 Aug 2020 03:25 - 15 Aug 2020 04:04 #226675
by GeorgeC
Replied by GeorgeC on topic Driving lights and foglights. Versions over world
Australia calling, getting in early before the UK and 99 other Nations reply with 101 opinions.
For me to have only the Daylight Running Lights "ON" I have the engine running and my switches set as below:
The Owners Manual, on Page 2-56, gives all the switch combinations required for any other, Night-time and Position Lights.
I think you may be confusing the DRLs with the Front Position Lights: See Page 6-48, #2 Front LED Position Light.
Edit: By using this switch position in the photo, this is the only way I can get the 'Day-time Dashboard Lights' to work as they are controlled by the dash-top sensor. In any other Switch positions, it reverts back to the 'Night-time Dashboard Lights', there you can use the little bar menu in the middle screen.
Last edit: 15 Aug 2020 04:04 by GeorgeC. Reason: I just had to include some of my personal rubbish!
15 Aug 2020 04:53 - 15 Aug 2020 04:54 #226678
Replied by mlines on topic Driving lights and foglights. Versions over world
As GeorgeC says, Day Running Lights (DRL) are not controlled by switches or humans. They are an EU (and other areas) legal requirement and come on when the engine is running and the main lights are off.
For the EU we have headlights with integrated "side marker" lights, these are controlled by the switches on the steering wheel. We have fog lights in the lower bumper with a fog light bulb (again controlled by the steering wheel switch) and a DRL bulb (controlled by the vehicle electronics)
I know some markets do not have the DRLs in the fog lamp housing and do not have the mounting point to fit them.
You can check if you have them by turning all lights off on the steering wheel switches and starting the engine, they will then light up.
Last edit: 15 Aug 2020 04:54 by mlines.
The following user(s) said Thank You: GeorgeC
- lookonimages
15 Aug 2020 07:10 #226681
by lookonimages
Replied by lookonimages on topic Re:Driving lights and foglights. Versions over world
In SA it is not legal requirement to have DRL though 80% news cars do come with them.
So when I start Jimny, all switches off, there is no lights "on".
To get the light in the red square to be on there is a specific setting on to set switch to.
So it seems that you as driver have choice to use them or not. The red square light inside main lights is more of a "parking" light.
I am going to try an find a set of UK fog lights that incorporate the daylight running lights to install. Will add own wiring if wiring is not there already.
If the wiring is not there I will add a controler like this that automatically switch on lights when voltage above 13v and switch lights off when engine is switched off.
15 Aug 2020 07:15 #226682
Replied by mlines on topic Re:Driving lights and foglights. Versions over world
I can get the UK fog light units and also the short lead ( if you find the wiring loom has the DRL connector in it
- Roger Fairclough
- Thank you received: 225
15 Aug 2020 07:52 #226684
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Driving lights and foglights. Versions over world
Interesting that the column lighting switch and the indicators are on the right.
Roger
Roger
Time to create page: 0.252 seconds
