Kingpin bearing drivers side replaced today.
19 Jun 2020 17:47 #223747
by BGBrit
Kingpin bearing drivers side replaced today. was created by BGBrit
- gusthegorilla
- Visitor
20 Jun 2020 07:48 - 20 Jun 2020 07:49 #223755
by gusthegorilla
Replied by gusthegorilla on topic Kingpin bearing drivers side replaced today.
:ohmy:
My God, Tony, I was expecting something half that size :ohmy:
Will be very interested in your journey home...I have two Jimnys, but I keep a VW Tiguan for pulling my tourer...might just rethink this, based on your adventures.....
....thanks for sharing, Tony....take care going home
Gus
Gus
Last edit: 20 Jun 2020 07:49 by gusthegorilla. Reason: Typo
20 Jun 2020 08:35 - 20 Jun 2020 08:38 #223756
by Scimike
Replied by Scimike on topic Kingpin bearing drivers side replaced today.
Hi Tony,
I have something half that size, maybe it's the camera perspective, but it looks massive compared to the Jimny. I am sure it's within the braked towing limit, but like Gus I also would be interested in your journey home and how the Jimny Performed. I may be rethinking and up sizing the van!
Have a great Journey back and take care. Let's us know how it goes.
Mike
Mike
Last edit: 20 Jun 2020 08:38 by Scimike. Reason: Can't spell.
The following user(s) said Thank You: BGBrit
- Thank you received: 1839
20 Jun 2020 09:36 #223759
Replied by Lambert on topic Kingpin bearing drivers side replaced today.
I look at that rig and think that's about perfect, you see a lot of golf sized cars towing that size van round these parts and I genuinely believe that a Jimny is a much better towing vehicle than a front wheel drive eurobox hatchback. I notice also that you have a roof box on your Jimny while it won't do much for your fuel consumption it will help your windage and make a bit more of a hole for the van to sit in. That said I would suggest a steady approach to side winds and even being overtaken by wagons as you have quite a side area to be aware of. My big trailer for Dreadnaught is only single storey so kinda within the profile of the car and it's twin axle wheel outside so very stable in itself but its heavy when full of sheep which insist on moving about as you drive which means it can try to lift and push the car more on undulating surfaces rather than following on behind nice and quietly. Has that van got a coupling stabilizer of some kind like an alko hitch?
Ultimately so long as you load it with a bit of nose weight and don't drive like you're in a demolition derby you are going to be fine
20 Jun 2020 10:16 #223761
by Scimike
I think you are spot on Lambert, but it's the shear size difference that plays with my mind.:laugh:
I pull about 500kg which it copes with fine, 50mph on the motorway is the about the comfortable limit, and it's a steady 30 - 40 on anything else.
If it can do similar with more weight and drag it opens up possibilities to a full size van, so really interested in how it performs.
Have you towed the sheep trailer on motorway, how did it do?
20 Jun 2020 10:26 - 20 Jun 2020 10:28 #223763
On the flat it sits at 60 or the prevailing limit for a trailer all day but any kind of prolonged inclination has the gear stick flying anything that you lose momentum on. There is a caveat to this though; I tend to drive at the back of queues not at the front of them
Last edit: 20 Jun 2020 10:28 by Lambert.
