steering issue
  • sickofjimnys
10 Jun 2020 19:36 #223464 by sickofjimnys
steering issue was created by sickofjimnys
OK, started the jalopy up on Monday with a funny low squeaking/grating noise from the front. Went off after a few miles but the steering began to feel 'heavy'! drove home but yesterday it was really heavy and I mean big pre-power steering cars heavy. Looked at the fluid reservoir but there seems to be fluid in there however Ive noticed what looks like a weeping power steering pipe just under the radiator - where its difficult to see clearly. Think it might be a steering box and/or pump issue resulting from the leaky pipe. Haven't heard any noise from the pump and if I stick my head under the bonnet while engine is running I can't hear anything or see anything untoward - apart from the wet pipe. The weather's been really awful today so haven't had a good look yet. I've lined up a second hand steering box from a scrapper but are there any thoughts on what it might be before I start investigating?
10 Jun 2020 20:10 #223466 by Scimike
Replied by Scimike on topic steering issue
Hi, it's possible the pipe is the issue but I would have expected it to be dumping oil on the floor before it had an effect on the steering. Is it possible this is an old oil leak or is it new?
One thing you can try is roll down the road engine on then off and see if the steering gets heavier or just stays the same. If it stays the same then it's definitely your hydraulic steering system. If it gets heavier it may be worth lifting both front wheels up and trying to move them by hand, if it's still heavy or impossible it may indicate a problem with something else, eg Kingpin bearing rusted solid.
Just thinking of possibilities, by no means a steering system expert.
Good luck
Mike
The following user(s) said Thank You: sickofjimnys
11 Jun 2020 05:42 #223469 by Lambert
Replied by Lambert on topic steering issue
Agree with the above especially lifting the front wheels off the floor and making sure they turn freely, to do that I would suggest undoing the steering drag link on the near side hub and then you have isolated and steering box and can check that separately too.
  • sickofjimnys
11 Jun 2020 11:36 #223481 by sickofjimnys
Replied by sickofjimnys on topic steering issue
Hi everyone, thanks for the replies thus far. Manged to have a look underneath this morning and it's a leaking pipe! It's the pipe coming from the fluid reservoir and it's leaking from under a short length of plastic sleeve - I think that's the low pressure return pipe? Also the fluid is below the level of the feed from the reservoir to the pump so I think it's been a (relatively) long-term leak. Will fix, top up and see what happens.
I seem to remember reading an old post on here describing a similar problem!
11 Jun 2020 11:41 #223482 by Scimike
Yep low fluid will starve the pump, so a top up should fix the problem. But the pipes a weak point which, sods law states, will fail at the most inappropriate time. So something to fix later.
Hope it's ok
Mike
  • sickofjimnys
11 Jun 2020 12:11 #223484 by sickofjimnys
Hi, I've sourced a pipe off a scrapper - should be OK but I am going to try a quick fix. As its a low pressure pipe I'm going to try something similar to a fix I did I an old Ducati bike exhaust I owned some years ago - a piece of tin, three jubilee clips and a piece of rubber. Im hoping if I clamp the rubber and tin over the hole (which appears to be very small) it will be robust enough to last a couple of weeks until I can access a ramp and do a couple of other jobs at the same time.
Time to create page: 0.105 seconds
