Trapped in the UK.
29 May 2020 06:31 #222968 by BGBrit
Replied by BGBrit on topic Trapped in the UK.
Keithy, a kind invite, and good advice.
Tony
29 May 2020 06:35 #222969 by BGBrit
Authorities with sense, Lambert, I'd rather look for hen's teeth. Luckily I'll not need to now with the lifting of the lockdown, a few weeks ago it looked like I'd be trapped here, now not.
Tony
29 May 2020 06:41 #222970 by BGBrit
Yes, Cailean, borders will be open soon, so I'll be freed. Confusion is often blown-away by experience. I'll let you know how I get on towing the caravan across the EU. Hopefully, the experience will not be too confusing and I'll arrive unscathed with both the Jimny and the Iona.
Tony.
29 May 2020 07:26 #222972 by HUN
Replied by HUN on topic Trapped in the UK.
Stick to motorways if you can, those have relative flat gradient compared to country roads. Keeping the minimum speed coul be a real challenge on some hills though. Good luck on that long journey Tony!
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
The following user(s) said Thank You: BGBrit
29 May 2020 19:59 #223006 by treps
Replied by treps on topic Trapped in the UK.
Unless I misunderstood the issue, EU countries have agreed to open borders from June 2. There are different quarantine issues to look at but from then you can travel. Actually, people are crossing via the eurotunnel now.
29 May 2020 21:15 #223012 by BGBrit
Yes treps, all looks fine now, I hope to cross by ferry into France - Calais. And straight through to home. Once I've fixed the petrol leak that is, which I have worked on today and posted in the tech chat tonight.
Cheers
Tony
Time to create page: 0.349 seconds
