Help - Roll Cage Install....
11 Apr 2020 10:55 #220932 by sniper
I am having a cage fitted and need some pictures of cage installs that have the front legs going through the top of the wing......
The tube goes down the "A" pillar and then joins the structural steel on the lower "A" pillar, behind the front wing, then triangulated to the chassis.
The guys at the workshop will be fitting it without me being present and I want to get as much info for them as possible...
Also, if anybody has any pictures of tidy tray-backs, it would help to see those also.
Thanks in advance,
sniper
  • X8GGY
11 Apr 2020 14:47 #220950 by X8GGY
Replied by X8GGY on topic Help - Roll Cage Install....
This is one of my old Vitaras - "Superzuki" that started this obsession of mine - with a cage that went though the top of the A-pillars...
The end of the tubes sat on steel plate bolted to the top of the wings. with the outer skin neatly trimmed around the tubes...
That prompted JackOnlyJack to ask for these questions of the landing area -
Might help? ;)
Most people have them external and running down to a sill side bar, but I've (personally) never like the "climbing frame" look...
11 Apr 2020 14:58 #220952 by jackonlyjack
This is what i was thinking about sniper
square 5-6mm plate in purple
then bar welded to it
also thinking of bolting plate to the part of A pillar
it's a bit rough but you get the idea :)
11 Apr 2020 15:33 #220954 by sniper
Replied by sniper on topic Help - Roll Cage Install....
Thats just about perfect Jack, thanks mate.....
sniper
  • X8GGY
11 Apr 2020 15:43 #220955 by X8GGY
You'd be better off having an upside down L shaped plate that landed on top as well rather than 'just' bolting to the side?
There's only 60mm from where the hinge is sitting in the photo to the outer skin of the bolted-on wing...
11 Apr 2020 15:49 #220956 by jackonlyjack
My cage idea is more to protect windscreen (not for roll over)
So my tube will be 38-45mm o/d
Time to create page: 0.099 seconds
