JB74 - Gen.4 5 wheel Tyre rotation
- Thank you received: 1927
- Bill Portland
- Thank you received: 77
If you don't rotate the spare does it mean you effectively have to throw it away when you come to replace the 4 worn tyres (unless you get another set of 4 of the same brand/model tyre)? Should you use a new (spare) on the same axle as a worn one?
Only issue I have now is that tpms will alert on the wrong wheel when the pressures drop! I'm guessing there's no simple way to reprogram it for the revised locations?
- CC Baxter
I remember GeorgeC took his off to improve vision, a man clearly ahead of the pack.
Chris
DAGZOOK wrote: Hello all,
I've got a question for all fellow Gen. 4 owners regarding tyre rotation. I'm of the understanding that that the spare on the Gen.4 doesn't have a TPMS sensor fitted. Does this mean that you'll have an error light displayed whilst the spare is fitted in a rotation situation? Or as others online seem to suggest, the spare won't transmit a pressure signal - but the wheel now mounted on the spare rack (with a TPMS sensor fitted and correctly inflated) will keep the system behaving?
I was hoping someone has conducted a real life test. I want carry out a 5 wheel rotation as I feel its best practice - I do relatively high millage on the tarmac but also use the car off road frequently whilst at the local shoot. I figure it'll be the best way to prolong the life of my tyres whilst also being mechanically sympathetic to the AWD system.
It would be a real nuisance if carrying out a 5 wheel rotation would mean you've got to persevere with a highly irritating warning light on the dash.
I will happily supply a definitive answer based on personal experience. I have a 2019 G4 Jimny and have undertaken the 5 Tyre rotation twice. All 5 wheels/tyres came with TPMS factory fitted and other than checking/resetting tyre pressures - it was a simple job. Just remember to check your tyre pressures when stone cold. Trust this helps clarify myth from fact.
