Gen4 - Selecting 4WD
11 Feb 2020 20:33 #218327 by OctaneJimny
Replied by OctaneJimny on topic Gen4 - Selecting 4WD
As said before you can change from 2H to 4H up to 60mph, make sure your wheels are in the straight ahead position and depress the accelerator
No need to press the clutch. Check the 4wd indicator light has come on and refer to the manual if not. But pressing the clutch will not be a problem but again make sure your wheels are facing straight forward to avoid a jolt through your transmission.
www.bigjimny.com/index.php/forum/8-my-ji...-ivory-manual#210539
Instagram: OctaneJimny
FB: Suzuki Jimny 4th gen (JB64 JB74) owners club
  • Dorsetdumpling
11 Feb 2020 21:25 #218339 by Dorsetdumpling
Replied by Dorsetdumpling on topic Gen4 - Selecting 4WD
I suppose that dipping the clutch would allow engine revs, and therefore presumably the vacuum to increase?
  • Andy2640
11 Feb 2020 21:29 #218343 by Andy2640
Replied by Andy2640 on topic Gen4 - Selecting 4WD
Dorsetdumpling wrote: I suppose that dipping the clutch would allow engine revs, and therefore presumably the vacuum to increase?
Im not sure sbout this vacuum thing, after all, wouldnt the engine be creating a vacuum effect when even idleing, or under engine breaking??
11 Feb 2020 21:41 - 11 Feb 2020 21:43 #218345 by Scimike
Replied by Scimike on topic Gen4 - Selecting 4WD
Yes it's present all the time, we even have a small tank to store it.
I believe the "accelerate slightly" is more to reduce the enormous bang as the front hubs engage. The forces under engine braking are larger than under slight acceleration, ie it's a speed match as they engage / disengage.
Just my idea.
Mike
Last edit: 11 Feb 2020 21:43 by Scimike.
11 Feb 2020 22:54 #218347 by Bob1050
Replied by Bob1050 on topic Gen4 - Selecting 4WD
Thanks for your thoughts/experience - appreciate your input. As Lambert indicates on a G3 the system is selected by a button/electrical connection - so depressing the clutch will have zero to add to the process. As for keeping the accelerator depressed - I can understand the logic. Andy2640 has discovered from personal experience on his G4, that not using the clutch doesn't lead to catastrophic transmission failure - Phew!
  • Daniel30
12 Feb 2020 12:09 #218369 by Daniel30
Replied by Daniel30 on topic Gen4 - Selecting 4WD
thought it was the same as a gen3 but the leaver connects the micro switch instead of a button on the dash, the lever is there for the more classic/ retro look :)
Time to create page: 0.271 seconds
