Follow me home light
- Lasse
08 Feb 2020 22:23 #218189
by Lasse
Follow me home light was created by Lasse
Hey guys
Is there someone out there who knows how to get the follow me home light to work on the gen4 .. I have been in the settings an put both the welcome light and the follow me home light to 20 seconds but it does not stay on when I take the key out..! The welcome light do get on when I unlock the car but it will still shot off after 10 sec...? Hmm is there anybody who has experience the same thing..?
09 Feb 2020 10:38 #218203
Replied by Soeley on topic Follow me home light
Have you tried the following from the handbook?
Guide me light (if equipped)
Guide me light has two functions of "To
home" and "To car" for improving your visibility in the dark.
"To home" function
Even after you leave the car, the ground
will be illuminated for a short while with this
function. You can turn on the front position
lights and the headlights in the low beam
setting for about 1 O seconds after the ignition switch is turned "LOCK".
To set the function:
1) Turn the lighting switch to "AUTO" position.
2) Turn the ignition switch to "LOCK" position.
3) Pull the lighting control lever toward
you once and open the driver's side
door within 60 seconds. Or pull the
lighting control lever toward you once
while the driver's side door is open.
Personally I haven't, I just have the "To Car" function set, and remember it only works if the headlight switch is set to Auto.
"To home" function
- Lasse
09 Feb 2020 10:45 #218204
by Lasse
Replied by Lasse on topic Follow me home light
I have tried it I think 10 times but no result- maybe it has to be dark outside when you do it..!! Hmm
09 Feb 2020 10:53 #218205
Yes it will only work when dark outside.
- Lasse
09 Feb 2020 18:49 #218238
by Lasse
Yeah I know the light only turn on when it’s dark but it thought I could only activate the setting I the dark but that didn’t help..! Don’t know what to do next..! Arrrhh!!
- Grima
09 Feb 2020 18:54 #218239
by Grima
Replied by Grima on topic Follow me home light
In day light just cover the light sensor on top of the dash.
