Tired of tyres gen 4
- Grima
21 Jan 2020 22:05 #217508
by Grima
Replied by Grima on topic Tired of tyres gen 4
I put larger tyres on a FL2 to get 25mm lift, the loss of power was massive and that was with a 2.2 diesel with turbo. The Gen4 has little power + low gearing, If you use it as a road car disabled scooters will be beeping you and your clutch will burn out. Big tyres = new gearing or parts will brake.
- Thank you received: 1998
22 Jan 2020 05:12 #217512
Replied by Lambert on topic Tired of tyres gen 4
Hippos and freepigs are made of chocolate though so any size increases on the tyres are going to be a problem. The Jimny is a much tougher creature and will stand a reasonable increase in tyre size fairly well. The problem is that without a lift there isn't actually that much room in the wheel wells before the tyres rub which is at odds with the size of the wheel arch as it looks like you should be able to get 35s in without any problems but you can't. Also the difference between a 195.80 and a 215.75 isn't actually that much but it could make a difference.
22 Jan 2020 05:23 #217513
Sorry I've just re read that, you put enough tyre under a freelander to gain 25mm extra clearance so you actually added 50mm to the diameter? I'm not surprised it didn't like it.
- Andy2640
22 Jan 2020 10:16 - 22 Jan 2020 10:21 #217525
by Andy2640
Replied by Andy2640 on topic Tired of tyres gen 4
As far as i know 235 is a straight swap.
I can highly recommend toyo open countey at plus tyres. They are a lovely balance on/off road.
And yes, the 235 on this forum was ash's blue sz5. Looks well nice.
Edit; However whilst they may look boss, i defer to the other members superior knowledge of the jimny. On mine are 215's, and this has made my jimby a joy to drive. Perhaps a safe bet going for 215 over 235.
All the best.
All the best.
Last edit: 22 Jan 2020 10:21 by Andy2640.
- zebraman
22 Jan 2020 10:21 #217526
by zebraman
Replied by zebraman on topic Tired of tyres gen 4
I'd love to hear about the driving experience from someone who did a straight swap to 235's. That is insane if we can do that.
22 Jan 2020 10:26 #217527
Replied by Soeley on topic Tired of tyres gen 4
I am thinking about getting the 205s Toyo when I swap.
