jimny rear door bodyshop bodge?
  • poppy
10 Nov 2019 11:09 #215533 by poppy
jimny rear door bodyshop bodge? was created by poppy
Having trouble with a body shop repairing my jimny after another driver drove in to the back door knocking the sparewheel into the rubber buffers. im saying tothem there is a space between the buffers and the spare wheel they have said there should be no gap betweenthe spare wheel and the buffers and the spare wheel rests on the buffers who is right.
10 Nov 2019 11:30 #215536 by jackonlyjack
A long time ago before any mod's i remember my standard size tyre 205/70/15 touching the rubbers
enough to leave an imprint on the tyre
10 Nov 2019 17:27 #215540 by Lambert
The tyre definitely rests on the rubber bungs.
10 Nov 2019 17:29 - 10 Nov 2019 17:32 #215541 by Scimike
My rear door spare hanging system has a small amount of damage (the internal door tyre support frame is slightly bent) so maybe not the best person to help. However I suspect that Jack is correct.
Looking at the tyre which is standard 205 if I could bend it all inline I would expect both rubber stops to just touch the tyre. As it is at the moment I have one pushed in by 4mm, the other clear by the same amount, ie by the same amount the mount on the door is bent.
Tried to bend it back but it will not budge :(
Edit :- Lambert posted as I typed, so It's confirmed. :lol:
Last edit: 10 Nov 2019 17:32 by Scimike.
10 Nov 2019 19:01 #215544 by Keithy
I had to modify my carrier for the larger tyres and change of offset....I extended the rubbers back out to the tyres.....stops it wobbling.
It's your car.....take the rubbers out and let the spare do it's thang......unless it identifies as a huge weight hanging on a bracket.
Time to create page: 0.976 seconds
