Newbie Gen 3 - Cruise Control / Accelerator Footrest question
  • Beaverhausen
11 Oct 2019 11:11 #214600 by Beaverhausen
Please be gentle guys, I've searched and with old threads don't know if things have changed.
Just bought a 56 plate 1.3 VVT manual. With no corrision :silly:
Spoke to a local (Bristol) after-market cruise control installer who claim they can't find a compatible cruise control unit.
Does anyone know if things have changed since 7 year-old threads which talk of the Commander (Australian post) or Waeco (UK) being fitted?
Failing that, as it's only a question of a sore ankle on long motorway trips - anyone know of a longer accelerator pedal more like a footrest that can be fitted? Everything on eBay or Amazon seems to be manufacturer/model specific (with no Jimny Gen 3 mentioned, of course).
Any help appreciated! I've always wanted to drive a tank, and now I am!
11 Oct 2019 11:27 #214601 by Lambert
Welcome to the forum. As far as I am aware there isn't much in the way of proprietary technology available to get real cruise control on a Jimny. I have looked at various types of hand throttle ideas but I haven't fitted one because I just don't want the risk of being accused of using it on the road in the event of a collision as all the ideas I have seen are not self cancelling and therefore a bit dubious on road. To counter this on a long drive I will wear my high laced Magnum boots and use them as an ankle brace.
The following user(s) said Thank You: Beaverhausen
  • Reason2doubt
11 Oct 2019 11:37 #214602 by Reason2doubt
Funny this came up now... I was days ago searching around for a solution to this ahead of the 6 hour drive from Newcastle to Berkshire for the BigJimny event next weekend.
My research had the same conclusion as lambert in that no solution I found had throttle cancel and I deemed it too risky to buy/fit my own as it sounded a bit complicated and not safe for roads.
And exactly as Lambert points out...big boots will do the trick (at least what I have found myself from longer journeys in the past).
11 Oct 2019 14:40 #214619 by RainerK
I am also checking for a cruise control and I found this:
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F260956744712
It is a Rostra 250-1223.
From the same supplier there are different kits and if you have manual transmission you might want to get a kit with a clutch switch.
Also there are different stalks and I am not sure yet which one is the best, left or right, long or short, ....
Gesendet von iPad mit Tapatalk
  • Beaverhausen
14 Nov 2019 14:10 #215626 by Beaverhausen
If you were at all still interested, I had AP500 and CM-35 stalk fitted today.
Took Motormods of Tewkesbury about 3 hours.
£450+vat - works a treat!
Time to create page: 0.169 seconds
