Dash cam
04 Oct 2019 17:01 #214310 by Keithy
Replied by Keithy on topic Dash cam
Been using a Transcend Drivepro220 64gb card for a few years......plays back on google maps lane guidance etc....aka records my route.....perfect thus far.
I'm upgrading to the Drivepro230.....128gb supported 9 hours of recording.
The following user(s) said Thank You: Daniel30
04 Oct 2019 17:08 #214311 by jackonlyjack
Replied by jackonlyjack on topic Dash cam
It records in 5min blocks continually
You can press lock button and save that block recording
05 Oct 2019 00:56 #214323 by zukebob
Replied by zukebob on topic Dash cam
I think the "choose based on what you want it to do" approach is the best. I have a Thinkware that is a couple of years old. I remember someone else (maybe Andy) buying a BlackVue. Both excellent quality. I'm not sure you would want to spend that much if your primary use is just to save videos of off-raod adventures.
Although you would probably want to purchase locally, this website has some decent information about features and brands:
blackboxmycar
05 Oct 2019 05:56 #214325 by Lambert
Replied by Lambert on topic Dash cam
Am I right in thinking that all monitor gps to give a location and speed data? Also I have heard reports that the police have been interrogating them for evidence of prior behaviour as in you get a tug for 54 in a 50 the copper then sees the dashcam and looks back through it and gets you for having a recording of you driving a tro'd lane or going deliberately off track causing damage and you then get done for that too because you incriminated yourself even though you weren't caught in the act. Ok none of us would do that because we have respect but my concern is still valid everyone has done something at some point that they would prefer remaining quiet. Still unconvinced.
05 Oct 2019 09:44 #214346 by jackonlyjack
Mine shows no speed on play back so i doubt it has gps info
05 Oct 2019 10:27 #214349 by facade
Replied by facade on topic Dash cam
I have a Nextbase 212, looks like the 612 Gadget refers too, except it is 1080 not 4k, and it doesn't have GPS.
Plus points
That slide mount is great, you can remove the camera without disturbing the aim.
Minus points
The file sizes are huge, given the poor quality of the video. (AVC codec @ 16.8 Mb/s 1920x1080 30fps)
The video is poor, you can only read the registration of a car that you get close enough to actually run into, but it is good enough to show that the car in front reversed into you, or swerved onto your side or something. Low light performance is awful, but to be fair, you'd expect it to be, when you have high intensity light sources and low lighting in the same frame.
The suction mount lets go when parked in hot weather.
The power adaptor fills the socket, and is joined to the lead rather than plugged on, so to power more than one device you need those massive adaptors, or you have to buy an extra long lead with a plug to use a 2 way USB 5V adaptor.
The following user(s) said Thank You: Lambert, Daniel30
Time to create page: 0.354 seconds
