Which pipe or pipes do I block up
01 Oct 2019 15:31 - 01 Oct 2019 15:35 #214110 by kirkynut
The photo in the guide was mine as I wrote the guide.
I just popped out to the garage and took a clearer shot as below. It's the pipe off the T piece that would go down to the hard pipes to provide the vacuum, so now it's sucking on the bolt.
By doing it this way you can leave the electronics as they are and as long as there's no vacuum leak from the pipe off this T piece that appears to go via 2 other T pieces to the inlet of my non VVT 2000 twin cam. Yours is VVT, so it might be a slightly different layout.
Then rip off everything on the axle and use a bit of plastic pipe to link the two parts of the steering knuckle/hub to stop water ingress, as per my guide photos. I forget where mine came from but wiper squirter pipe will likely be right and can be obtained easily from Halfords, motor factors or the internet.
Last edit: 01 Oct 2019 15:35 by kirkynut.
  • Tinbox
01 Oct 2019 19:05 #214131 by Tinbox
Replied by Tinbox on topic Which pipe or pipes do I block up
Thanks the new picture is clearer. Have you plugged both tubes with screws. My manual hubs should arrive on Thursday so weather permitting I’m going to have a go at sorting this out once and for all!!!!
01 Oct 2019 20:18 #214142 by kirkynut
Tinbox wrote: Thanks the new picture is clearer. Have you plugged both tubes with screws. My manual hubs should arrive on Thursday so weather permitting I’m going to have a go at sorting this out once and for all!!!!
I only seemed to have one to block. I have no vacuum leaks.
  • Tinbox
02 Oct 2019 10:23 #214166 by Tinbox
Oops!!! now I’m confused I’ve blocked both pipes and the green light is still flashing. Any ideas?????
02 Oct 2019 10:32 #214167 by facade
Tinbox wrote: Oops!!! now I’m confused I’ve blocked both pipes and the green light is still flashing. Any ideas?????
Short out the switch, there must still be a vacuum leak.
There are two electric solenoid vacuum valves. Both should route atmosphere to the hubs when off (via a little filter), and block the vacuum line.
When either is activated, it changes over to route vacuum to one side of the hub, and atmospheric pressure pushes the hub over from the other side through the non-activated valve.
If the disengage solenoid valve seizes up, it sticks so that the vacuum line connects to atmosphere, and you can never build up a vacuum in the tank, or activate the vacuum switch even if the engage solenoid valve is working.
  • Tinbox
02 Oct 2019 11:54 #214169 by Tinbox
Thanks. I think bit by bit I’m beginning to understand the workings of the vacuum system. I am going to try using a scotchlok across the two white wires as Riccy suggested. Hopefully once I’ve fooled the electronics all should be good. My manual hubs have arrived today so it’s out with the t10 torx tomorrow. Any pit falls I need to look out for. My hubs are designed for the Jimny so I’ve no spacers etc to worry about. I’ll post the result on here when it’s done. Thanks again for all the help so far. Not only are Jinny’s great vehicles but clearly the owners are decent and helpful folk too!!!
Time to create page: 0.199 seconds
