Does your Jim rev?
  • zeek
26 Nov 2010 10:35 #6522 by zeek
Does your Jim rev? was created by zeek
Hi guys
I've got a query about the 2002 Jimny which we've got. I don't drive it that often (Mrs Zeek does) but when I've used it recently, it feels like it doesn't want to go as much as it used to. It seems to rev freely in all gears up to about 3500, then that's it. You can get it up to 4500 in 5th with a good run, but you need momentum for that! It doesn't sound like it's going to blow up or anything, it just runs out of steam. On an A-road, the slightest incline will really make it work, the speed drops quickly, and if you didn't down change, you'd get left behind causing a jam.
It might be my imagination, and the little 1.3 engine is giving everything it always did, but I haven't driven any others to compare - anyone got any ideas? Do yours rev freely right through the range?
Thanks in advance!
26 Nov 2010 11:01 #6523 by mlines
Replied by mlines on topic Re: Does your Jim rev?
This is a characteristic of the catalytic converter on the way out.
If so it will get worse and worse until it will not rev at all
  • Keefe
26 Nov 2010 11:05 #6524 by Keefe
Replied by Keefe on topic Re: Does your Jim rev?
Hi,
Sounds like a filter needs changing somewhere to me.
Perhaps air or fuel or both?
Somebody will tell you soon, I'm sure.
Mine has done 175,000 miles and will easily run up to 75 mph and revs freely although the lift and tyres make it quite interesting at those speeds on the motorway.
Just seen the reply re: the cat. I hadn't thought of that.
K
  • zeek
26 Nov 2010 11:30 #6525 by zeek
Replied by zeek on topic Re: Does your Jim rev?
Thanks guys...I'll go and check these bits out. The air filter is new though, so unlikely to be that.
Is there any way I can check the condition of the cat without taking it out...Even that should be fairly simple (assuming the nuts haven't rusted to nothing!)?
It had a new pre-cat o2 sensor last year too.
  • zeek
26 Nov 2010 11:35 #6526 by zeek
That's the other thing - apparently, it is eager to stall at low (parking) revs... Presumably this could also point to a cat issue?
  • gazert
26 Nov 2010 12:30 #6527 by gazert
Replied by gazert on topic Re: Does your Jim rev?
I had the same symptoms when I baught mine.
Turned out it was huge amount of slack in the accelerator peddle!
May be worth checking throttle cable tension, it's very easy to adjust.
Time to create page: 0.170 seconds
