Cloudy cluster.
- Thank you received: 2004
26 Jun 2019 16:34 #210324
Cloudy cluster. was created by Lambert
Grrrrrrrrrr. Mother has just given me Dreadnaught back after she has been running an errand. She has found my industrial hand wipes. She has used them on the dashboard and more importantly on the instrument cluster. It is now cloudy like it's been wire brushed. Tried glass polish, no. Tried soapy water, no. What I had thought was to remove it and machine polish it? Anyone solved something like this?
26 Jun 2019 16:49 #210326
Replied by Riccy on topic Cloudy cluster.
hot air gun
if its perspex type material it should be possible to gently heat it to smooth it out a little.
otherwise you could leave it on and set fire to the car, thus also removing the problem?! :laugh:
26 Jun 2019 17:10 #210327
Replied by Lambert on topic Cloudy cluster.
Think I'll remove it to try that. Cheers mate!
- Thank you received: 706
26 Jun 2019 19:03 #210336
Replied by jackonlyjack on topic Cloudy cluster.
You could try a different type of wipe
like a zep wipe
like a zep wipe
26 Jun 2019 19:53 #210339
Zep wipes are what has been used. It doesn't seem to be scratched, it definitely seems to be more of a residue. Heat does not touch it in amounts I am comfortable applying. It does clear when wetted but drying causes the cloudiness. AG tar remover did improve it marginally. So did a little bit of AG extra gloss protection. I'm wondering if it needs one of those rubber finger da pads to apply friction to remove the residue?
- Jimx5
26 Jun 2019 20:46 #210340
by Jimx5
Replied by Jimx5 on topic Cloudy cluster.
My dash cluster 'glass' which is plastic had stains that were literally etched in to the plastic, i removed the dash cluster and removed the plastic completely.
Then possibly 10-15mins with G10 rubbing compound (any good polish will do, but nothing as aggressive as T-Cut) and the plastic came up crystal clear.
